ST STM32F4xx ARM Cortex-M4F Demo
Using IAR EWARM development tools
STM32F407ZG_SK starter kit board
This page documents a FreeRTOS ARM Cortex-M4F demo application that targets an STMicroelectronics
STM32F4xx microcontroller.
An IAR project is provided that is pre-configured to run on the development board provided
as part of the STM32F407ZG-SK starter kit.
The FreeRTOS ARM Cortex-M4F port supports a full interrupt nesting model, and never
completely disable interrupts. The port can only be used with hardware
floating point support turned on in the compile time options of the project
used to build the source files. ARM Cortex-M4 devices that don't include a floating
point unit should not use this port, but instead use the FreeRTOS ARM Cortex-M3 port layer.
Note: The demo presented on this page tests the FreeRTOS floating
point support by forcing interrupts that use the floating point unit to nest to
a level of three deep. The nesting starts from the tick hook function - which
is called from the FreeRTOS tick interrupt code. Removing this part of the test
will greatly improve the efficiency of the RTOS kernel, and can be achieved by setting
configUSE_TICK_HOOK to zero in FreeRTOSConfig.h.
Note 2: If this project fails to build then it is likely the version of IAR
Embedded Workbench being used is too old. If this is the case, then it is also
likely that the project file has been (silently) corrupted and will need to be
restored to its original state before it can be built even with an updated IAR version.
IMPORTANT! Notes on using the FreeRTOS IAR STM32F4 demo project
- Source Code Organisation
- The Demo Application
The FreeRTOS zip file download contains source code for all the FreeRTOS ports,
and every demo application project.
It therefore contains many more files than are required to build and run the ST STM32F407ZG demo. See the
of the downloaded files, and information on creating a new project.
The IAR Embedded Workbench workspace for the STM32F4xx demo is called RTOSDemo.eww,
and is located in the FreeRTOS/Demo/CORTEX_M4F_STM32F407ZG-SK directory of the
official FreeRTOS .zip file download.
The STMicro ARM Cortex-M4F Demo Application
Floating point instructions being used from tasks.
Floating point instructions being used from interrupts that nest 3 deep.
Note: The nesting starts from the tick hook function - which
Software timers.
Queues.
Mutexes.
Semaphores.
Malloc failed, stack overflow, tick and idle hook functions.
The demo application can be configured to provide very simply 'blinky' style
functionality, or a full and comprehensive test and demonstration of the
FreeRTOS functionality. The #define mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY constant,
which is defined in main.c, is used to switch between the two modes.
Demo application tasks are split between standard demo tasks, and demo specific
tasks. Standard demo tasks are used by all FreeRTOS ports and demo applications.
They have no purpose other than to demonstrate the FreeRTOS API, and test a port.
Description
Set to 1
This creates a very simple example that creates three
standard demo "flash" tasks. Each of the three tasks toggles an
LED at a fixed but different frequency. LEDs STAT1, STAT2 and STAT3
are used.
Set to 0
This is a very comprehensive demo that creates 46 tasks before
starting the RTOS scheduler, then continuously dynamically creates and
deletes another two tasks as the application executes.
It creates a lot of queues, a software timer, and different types of semaphore.
The tasks consist mainly of the
standard demo tasks.
The demo includes application specific "register test" tasks.
These are idle priority tasks that start by filling all the generic
and floating point registers with known
values. The tasks then repeatedly check that
each register maintains the value written to it, as it enters and
exits the Running state, for the lifetime of the task. Each of the two register check
tasks uses a different set of known values, and a value being
unexpectedly changed is symptomatic of an error in the context switching
mechanism.
The floating point interrupt nesting test starts in the tick hook
function. The tick hook function is an optional application defined
function that is called from the real time kernels tick interrupt
if configUSE_TICK_HOOK is set to 1 in FreeRTOSConfig.h. The tick
hook function fills the floating point registers with a known value,
then forces a medium priority interrupt to interrupt it. The medium
priority interrupt fills the floating point registers with a different
value, before it too forces a high priority interrupt to interrupt it.
The high priority interrupt fills the floating point registers with
yet another value. As the interrupt nesting stack then unwinds, first
the medium priority interrupt checks that the floating point registers
contain the values that it wrote to them, and then the tick hook function
(the lowest priority interrupt) checks that the floating point registers
contain the values that it wrote to them.
A 'check' software timer is created and started to periodically inspects the standard
demo tasks and register test tasks, to ensure they are all operating
as expected, and have never reported an error. The check timer
callback function toggles LED STAT4 to give visual feedback of the
system status. If LED STAT4 toggles every 3 seconds, then the
check software timer has not discovered any problems with the execution of the test and demo
tasks. If the rate at which LED STAT4 toggles increases to every 200
milliseconds, then the check software timer has discovered a problem
in at least one task.
Like the simple flasher demo, the comprehensive demo
creates the standard demo flash tasks, which toggle LEDs STAT1, STAT2 and STAT3
at fixed but different frequencies.
The demo uses the LEDs that are built onto the starter kit hardware, so no
hardware set up is required.
Ensure the target hardware is connected to the host computer using a
suitable debugger interface. A J-Link lite is provided in the starter kit.
Open the RTOSDemo.eww Embedded Workbench workspace
from within the Embedded Workbench IDE.
Select "Build All" from the Embedded Workbench "Project" menu - the demo
application should build without errors.
When the build completes, select "Download and Debug" from the Embedded Workbench
"Project" menu (or just press CTRL+D) to program the microcontroller flash memory,
and start a debug session. The application will start to run, and then
break at the start of the function main().
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_M4F_STM32F407ZG-SK/FreeRTOSConfig.h.
configTICK_RATE_HZ
configLIBRARY_LOWEST_INTERRUPT_PRIORITY and configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY
Whereas configKERNEL_INTERRUPT_PRIORITY and configMAX_SYSCALL_INTERRUPT_PRIORITY
are full eight bit shifted raw values, defined to be used directly in the ARM Cortex-M4F NVIC registers,
are equivalents defined using just the 4 priority bits available on the STM32.
The ST Standard Peripheral Library function NVIC_Init(), and the CMSIS
library function NVIC_SetPriority(), both require the unshifted 4 bit format.
Cortex-M vendors implement a different number of priority bits and supply library
on STM32 microcontrollers the lowest priority you can specify is in fact 15 - this is defined by the constant
It is also recommended to ensure that all four priority bits are assigned as
being preemption priority bits, and none as sub priority bits, as they are in the provided
demo.
Unlike most ports, interrupt service routines that cause a context switch have
As an example, this demo provides an interrupt service routine called
EXTI9_5_IRQHandler(), which is defined in main.c. This interrupt is triggered by
pressing the button marked "USER" on the starter kit hardware. The interrupt
uses a semaphore to synchronise with a task, and calls portEND_SWITCHING_ISR
to ensure the interrupt returns directly to the task. The function is shown below:
void EXTI9_5_IRQHandler(void)
/* Only line 6 is enabled, so there is no need to test which line generated
the interrupt. */
EXTI_ClearITPendingBit( EXTI_Line6 );
task with an interrupt. First the handler releases a semaphore.
lHigherPriorityTaskWoken has been initialised to zero. */
higher than the currently executing task (the task that this interrupt
interrupted), then lHigherPriorityTaskWoken will have been set to pdTRUE.
Passing pdTRUE into the following macro call will cause this interrupt to
return directly to the unblocked, higher priority, task. */
configuration constant.
selected.
Source/Portable/MemMang/heap_2.c is included in the ARM Cortex-M4F demo application project to provide the memory
full information.
