Renesas RZ/T RTOS Demo
Including FreeRTOS-Plus-CLI,
Using IAR and GCC embedded compilers
This page documents a FreeRTOS demo application for the
Renesas RZ/T embedded processor, which has an ARM Cortex-R4F core. Two projects
are provided, allowing the demo to be built with with the
IAR Embedded Workbench or
GCC embedded development tools. The demo targets the Renesas
RZT1 RSK
(Renesas Starter Kit).
Both projects include build options that allow the creation of a simple blinky demo
or a comprehensive demo, and use:
The FreeRTOS Cortex-R4F kernel port (the version for embedded processors
that do not also include the ARM Generic Interrupt Controller, or GIC),
which supports interrupt nesting.
Either the IAR Embedded Workbench or e2studio IDE (depending on the
project file used)
The FreeRTOS zip file contains source code for all the RTOS ports and all the
RTOS demo applications. Only a small subset of these files are required by the
Renesas RZ/T ARM Cortex-R4F demo. The Source Code Organization page describes
the structure of the FreeRTOS zip file download, and provides information on
creating a new RTOS project.
The e2studio Eclipse project file used to build the demo with GCC, and the IAR
Embedded Workbench project file used to build the demo with the IAR compiler, are
both located in the FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR
directory.
The e2studio GCC and IAR projects build the same RTOS demo application, and both include
files that are contained in the /FreeRTOS-Plus directory, so the projects will
not build if the /FreeRTOS-Plus directory has been deleted or moved from
its default location.
The Renesas RZ/T ARM Cortex-R4 Demo Application
Hardware and software set up
The demo documented on this page uses the UART to USB converter and LEDs built
onto the RZT1 RSK, so no hardware setup is required.
The simply blinky example
The blinky example is built when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set
to 1 in main.c. When this is done, main() calls main_blinky():
The main_blinky() Function:
main_blinky() creates an RTOS queue, a queue send task, and a queue receive
task, then starts the scheduler.
The Queue Send Task:
The Queue Receive Task:
in main_blinky.c.
prvQueueReceiveTask() blocks to wait for data to arrive on the RTOS queue.
Each time the value 100 is received from the queue it toggles LED 0.
As data is sent to the queue every 200ms, the LED will toggle every
200ms.
The comprehensive example is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set
to 0 in main.c. When this is done, main() calls main_full():
The main_full() Function:
main_full() creates a set of standard demo tasks, some application specific
test tasks, a command line interface (CLI) task, a pseudo randomiser task, and
The pseudo randomiser task is just used to ensure some variation is
added to the sequence in which the test tasks execute, and in so doing,
improve the test coverage.
The command line interface (CLI)
The CLI is implemented using the FreeRTOS-Plus-CLI
extensible command line interface, and uses the UART to USB converter
connector (J8) at 19200 baud
for its input and output. As always with FreeRTOS-Plus-CLI, type "help" to
see a list of registered commands.
The "Reg Test" Tasks:
The reg test tasks test the context switching mechanism by filling each
embedded processor register with a known value, then continuously checking that each
register maintains its expected value for the lifetime of the task.
The "Check" Task:
The "Check" task monitors the status of all the other tasks in
the system, looking for a task either stalling, or reporting an error.
It toggles LED 0 each time it iterates around its implementing loop.
If the LED is toggling every three seconds then the check task has not
detected any stalled tasks, or detected any errors. If the LED
is toggling every 200ms then at least one error has been found.
Build Instructions
Note that the IAR project references common files from both the /FreeRTOS-Plus
and /FreeRTOS/Demo/Common directories, so the project will not compile
if either directory has been deleted or moved.
Open FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/RTOSDemo.eww
from within the IAR Embedded Workbench IDE.
Open the project's main.c file, and set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to generate either
the simple blinky demo, or the full test and demo application, as
required.
Select "Build All" from the IDE's "Project" menu to build the RTOS demo.
Ensure the target hardware is connected to the host computer using an
appropriate debug interface (J-Link, I-Jet, etc.).
Select "Options" from the IDE's "Project" menu. The options window will
appear. In the options window first select the "Debugger" category, then ensure
the "driver" setting is correct for your debugger connection (J-Link, I-Jet, etc.).
Close the Options window when the setting is correct.
Select "Download and Debug" from the IDE's "Project" window to download
the built executable to the ARM Cortex-R4F, and start a debug session.
Building and executing the demo application - e2studio
Note that the e2studio Eclipse project
uses both virtual folders and links that reference files from both the /FreeRTOS-Plus and /FreeRTOS/Demo/Common
directories. The [virtual] file structure viewed in the Eclipse project explorer will
not match the [actual] file structure viewed on the disk, and the project will not
built if either referenced directory is missing or has been moved.
Open e2studio and either create a new workspace or select an existing
workspace when prompted.
Select "Import" from the IDE's "File" menu to bring up the import
dialog box.
In the Import dialog box, select "General->Existing Projects Into Workspace"
then browse to and select the FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR
directory. A project called "RTOSDemo" will be visible.
Ensure RTOSDemo is checked and that Copy Projects Into Workspace is
not checked before clicking "Finish".
Import FreeRTOS_Demo into the Eclipse workspace without
copying it into the workspace.
Open main.c and set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to generate either
required.
appropriate debug interface, for example, a J-Link.
Select "Build All" from the IDE's "Project" menu.
After the build completes, select "Debug Configurations..." from the
IDE's "Debug" menu, and configure and run a debug configuration that is
appropriate for your selected connection method.
The clickable screenshots below show a configuration that is using a J-Link
JTAG interface.
When an interrupt occurs, the RZ/T real time embedded processor hardware will
vector directly to a peripheral specific interrupt handler, rather than to the
ARM Cortex-R IRQ vector. Therefore, each interrupt handler installed by the
application must include an assembly file wrapper that performs some house keeping,
then branches to the FreeRTOS interrupt entry code. The FreeRTOS interrupt entry
code manages interrupt entry, including interrupt nesting, before calling a
standard C function in which the interrupting peripheral is serviced.
For the purpose of this example, assume the C portion of the interrupt handler
is called InterruptHandler() - as shown below. A full example is provided after
the sections that demonstrate how to write the assembly file wrappers:
The C portion of the interrupt handler - this is where the interrupting peripheral is serviced
For the purposes of this
example, assume the assembly wrapper is called InterruptHandlerWrapper(). The
wrapper must save a pointer to the C portion of the handler function into a
variable called pxISRFunction, then branch to a function called
FreeRTOS_IRQ_Handler (which is provided by the RTOS).
The syntax required to add the assembly file wrapper to each C interrupt handler
function is dependent on the compiler used (IAR or GCC). Examples and further
references are provided below.
Writing an assembly wrapper for an ISR: IAR
When using the IAR tools, the assembly wrapper must be implemented in an assembly
file. A generic example is provided below. Further examples can be
found in /FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/System/IAR/Interrupt_Entry_Stubs.asm.
SECTION intvec:CODE:ROOT(2)
ARM
/* Variables and functions from the RTOS port. */
EXTERN pxISRFunction
EXTERN FreeRTOS_IRQ_Handler
/* The C portion of the interrupt handler. */
EXTERN InterruptHandler
/* Functions implemented in this file. */
PUBLIC InterruptHandlerEntry
/* The implementation of InterruptHandlerEntry. */
InterruptHandlerEntry: /* Save used registers (probably not necessary). */
PUSH {r0-r1} /* Save the address of the C portion of this handler into pxISRFunction. */
LDR r0, =pxISRFunction
LDR R1, =InterruptHandler
STR R1, [r0] /* Restore used registers. */
POP {r0-r1} Branch to the RTOS IRQ handler. */
B FreeRTOS_IRQ_Handler
The assembly wrapper for the C interrupt handler function - IAR
Writing an assembly wrapper for an ISR: GCC
When using the GCC tools, the GCC inline assembler and the 'naked' function attribute
can be used to include the assembly wrapper in a C file. A generic example is
found in the /FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/src/FreeRTOS_tick_config.c,
/FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/src/cg_src/r_cg_scifa_user.c and
/FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/src/full_demo/IntQueueTimer.c
source files.
#include "FreeRTOS.h"
/* The prototype for the function that implements the assembly file wrapper must
use the naked attribute - which prevents the compiler from adding any function
prologue or epilogue assembly code. */
void InterruptHandlerWrapper( void ) __attribute__((naked));
/* The implementation of InterruptHandlerEntry. This is a naked function and
must not include and C code! */
__asm volatile ( /* Save used registers (probably not necessary). */
"PUSH {r0-r1} tn" /* Save the address of the C portion of this handler in pxISRFunction. */
"LDR r0, =pxISRFunction tn"
"LDR r1, =InterruptHandler tn" /* Restore used registers. */
"STR r1, [r0] tn"
"POP {r0-r1} tn" Branch to the RTOS IRQ handler. */
"B FreeRTOS_IRQ_Handler "
The assembly wrapper for the C interrupt handler function - GCC
Writing the C portion of an ISR: IAR and GCC
If an ISR causes a task of equal or higher priority than the currently executing
task to leave the Blocked state then the ISR must request a context switch before
the ISR exits. When this is done the interrupt will interrupt one RTOS task,
but return to a different RTOS task.
The macros portYIELD_FROM_ISR() (or portEND_SWITCHING_ISR()) can be used to
request a context switch from within an ISR.
The following source code snippet is provided as an example. The example ISR
uses a direct to task notification
to synchronise with a task (not shown), and calls portYIELD_FROM_ISR()
to ensure the interrupt returns directly to the task.
void InterruptHandler(void)
Dummy_ClearPendingInterrupt();
lHigherPriorityTaskWoken is initialised to zero. */ vTaskNotifyGiveFromISR()( xTaskToNotify, &lHigherPriorityTaskWoken );
The C portion of an interrupt service routine
interrupt service routine.
The RTOS Cortex-R port is a generic port that is tailored to specific embedded
processor implementation using macros and callback functions. The RTOS tick
interrupt is configured using the following two macros, which are defined in
the FreeRTOSConfig.h file supplied with the RTOS demo application:
configSETUP_TICK_INTERRUPT()
This must call the function that configures a timer to generate the
tick interrupt, and install FreeRTOS_Tick_Handler() as the timers interrupt
service routine (via an assembly wrapper, as described above).
In the
provided demo application the macro is set to call
vConfigureTickInterrupt(), which is defined in
and configures the compare match timer 5 (CMT5) to generate the RTOS
tick.
configCLEAR_TICK_INTERRUPT()
This must clear pending interrupts in whichever timer is used to
generate the RTOS tick.
In the provided demo application the macro is set to clear the interrupt
in CMT5, as the RTOS tick interrupt is generated by CMT5.
The RTOS Cortex-R port is a generic port that is tailored to a specific embedded
processor implementation using macros and callback function. In the RZ/T RTOS port
the generic IRQ handling code (the code that manages interrupt entry) calls
vApplicationIRQHandler(), and vApplicationIRQHandler() must be provided by the
application.
In the provided demo application vApplicationIRQHandler() is implemented in
FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/src/FreeRTOS_tick_config.c, and
replicated below:
/* The function called by the FreeRTOS IRQ handler, after it has managed
interrupt entry. This function creates a local copy of pxISRFunction before
re-enabling interrupts then calling the handler pointed to by pxISRFunction.
pxISRFunction is set by the assembly wrapper added to each interrupt handler. */
void vApplicationIRQHandler( void )
ISRFunction_t pxISRToCall = pxISRFunction;
portENABLE_INTERRUPTS();
/* Call the installed ISR. */
pxISRToCall();
The implementation of vApplicationIRQHandler() for the RZ/T RTOS port
FreeRTOS ARM Cortex-R4F port demo application specific configuration
FreeRTOS requires exclusive use of the SVC interrupt.
Source/Portable/MemMang/heap_4.c is included in the ARM Cortex-R4 RTOS demo application project to provide the memory
full information.
