Atmel SAMD20 ARM Cortex-M0+ Demo
FreeRTOS and FreeRTOS-Plus-CLI Built Using Atmel Studio and GCC
Atmel SAMD20 ARM Cortex-M0+ MCU
SAMD20 Xplained PRO
This page describes a demo project that uses FreeRTOS and FreeRTOS-Plus-CLI on the SAMD20 Cortex-M0+ microcontroller from Atmel.
The project uses the FreeRTOS ARM Cortex-M0 GCC port, builds with the free Atmel Studio IDE (which uses the Visual Studio framework and includes a kernel aware FreeRTOS plug-in), and targets the very low cost SAMD20 Xplained Pro evaluation board.
The command line interface character input and output uses drivers provided by Atmel in their Atmel Software Framework (ASF).
A #define is used to switch the build between a simple blinky style application, and a comprehensive test and demo application that incorporates the FreeRTOS-Plus-CLI component.
The Atmel Studio IDE with Kernel Aware FreeRTOS Plug-in
IMPORTANT! Notes on using the SAMD20 ARM Cortex-M0+ Demo
The FreeRTOS download contains the source code for all the FreeRTOS ports, so contains many more files than are needed by the SAMD20 demo. See the Source Code Organization section for a description of the directory structure.
The Atmel Studio solution file is called RTOSDemo.atsln, and is located in the FreeRTOS/Demo/CORTEX_M0+_Atmel_SAMD20_Xplained directory.
Building and Running the ARM Cortex-M0+ RTOS Application
  1. Open FreeRTOS/Demo/CORTEX_M0+_Atmel_SAMD20_Xplained/RTOSDemo.atsln in the Atmel Studio IDE.
  2. Locate the mainCREATE_SIMPLE_BLINKY_DEMO_ONLY definition at the top of main.c. Set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to 1 to create the simple blinky demo, or 0 to create the comprehensive demo that also includes the command line interpreter.
  4. Connect a USB cable between the USB port on the SAMD20 Xplained Pro board and the host computer.
  5. Select "Start Debugging and Break" from the Atmel Studio "Debug" menu to program the microcontroller flash memory and start a debug session.
Building with mainCREATE_SIMPLE_BLINKY_DEMO_ONLY set to 1 results in main() calling main_blinky(). The main_blinky() demo is described below.
    The queue send task is implemented by prvQueueSendTask() in main_blinky.c.
    prvQueueSendTask() repeatedly blocks for 200 milliseconds before sending the value 100 to the queue that was created in main_blinky().
    The queue receive task is implemented by prvQueueReceiveTask() in main_blinky.c.
    prvQueueReceiveTask() repeatedly blocks on attempts to read from the queue that was created in main_blinky(), toggling the LED each time data is received. The queue send task sends data to the queue every 200 milliseconds, so the LED will toggle every 200 milliseconds.
Building with mainCREATE_SIMPLE_BLINKY_DEMO_ONLY set to 0 results in main() calling main_full(). The main_full() demo is described below.
  • The main_full() Function:
    main_full() creates a set of standard demo tasks, some application specific test tasks, a task that manages FreeRTOS-Plus-CLI, and a timer. It then starts the scheduler.
  • FreeRTOS-Plus-CLI Task:
    ARM Cortex-M0+
    Click to enlarge
    The SAMD20 Xplained Pro board connects to a host computer by a single USB cable. The USB connection provides both a debugger interface and a virtual COM port connection. The virtual COM port is used to provide the character input and output required by the command line interface (CLI). The CLI can therefore be accessed from any serial terminal program, such as Hyper Terminal, or as shown in the image on the right, Tera Term.
    The image shows COM 20 being used, but it is likely that the virtual COM port will enumerate to a different port number on your host computer.
    As always with FreeRTOS-Plus-CLI, the 'help' command will display a list of registered (and therefore available) commands. The image was captured after executing the 'run-time-stats' command, which generates a table showing the amount of CPU time that has been consumed by each RTOS task.
  • The "Reg Test" Tasks:
    These fill the registers with known values, then check that each register maintains its expected value for the lifetime of the task. Each task uses a different set of values. A register containing an unexpected value is indicative of an error in the context switching mechanism.
  • The "Check" software Timer:
    The check software timer period is initially set to three seconds. Its callback function checks that all the standard demo tasks, and the register check tasks, are not only still executing, but are executing without reporting any errors. If the check timer callback discovers that a task has either stalled, or reported an error, then it changes the period of the check timer from the initial three seconds, to just 200ms. The callback function also toggles the LED to give a visual indication of the system status: If the LED is toggling every three seconds then no issues have been discovered. If the LED is toggling every 200ms, then a problem has been discovered in at least one task.
Configuration items specific to these demos are contained in FreeRTOS/Demo/CORTEX_M0+_Atmel_SAMD20_Xplained/RTOSDemo/src/config/FreeRTOSConfig.h. The constants defined in FreeRTOSConfig.h can be edited to meet the needs of your application. In particular -
Each port #defines 'BaseType_t' to equal the most efficient data type for that processor. All ARM Cortex-M0+ ports define BaseType_t to be of type long.
Source/Portable/MemMang/heap_4.c is included in the ARM Cortex-M0+ demo application project to provide the memory allocation required by the RTOS kernel. Please refer to the Memory Management section of the API documentation for full information.
