Atmel ARM Cortex-M7 SAMV71/SAME70 RTOS Demo
Using the IAR, Atmel Studio (GCC), and ARM Keil Embedded Development Tools
SAMV71 Cortex-M7 microcontroller from Atmel
This page documents:
As the SAM V70 includes a superset of functionality, so the SAM V70 Xplained Ultra board can also be used to evaluate running the RTOS on SAM V70, SAM S70, and SAM E70 ARM Cortex-M7 devices.
Atmel Studio with the FreeRTOS Viewer window open. Click to enlarge.
IMPORTANT! Notes on using the SAMV7 and SAME7 ARM Cortex-M7 RTOS demo
The FreeRTOS zip file download contains the source files for all the FreeRTOS ports, and projects for all the demo applications. It therefore contains many more files than are needed by this project. See the Source Code Organization section for a description of the directory structure and information on creating a new FreeRTOS project.
The Atmel Studio project for the SAMV7 demo application is called RTOSDemo.atsln, and is located in the FreeRTOS/Demo/CORTEX_M7_SAMV71_Xplained_AtmelStudio directory.
The Atmel Studio project for the SAME7 demo application is called RTOSDemo.atsln, and is located in the FreeRTOS/Demo/CORTEX_M7_SAME70_Xplained_AtmelStudio directory.
The IAR Embedded Workbench for ARM workspace for the SAMV7 demo application is called RTOSDemo.eww, and is located in the FreeRTOS/Demo/CORTEX_M7_SAMV71_Xplained_IAR_Keil directory.
The ARM Keil project for the SAMV7 demo application is called RTOSDemo.uvprojx, and is located in the FreeRTOS/Demo/CORTEX_M7_SAMV71_Xplained_IAR_Keil directory.
The Atmel ARM Cortex-M7 Demo Application
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1 then main() calls main_blinky(). main_blinky() creates a very simple demo as follows:
    The queue send task is implemented by prvQueueSendTask() in main_blinky.c. It sends the value 100 to the queue every 200 milliseconds.
    The queue receive task is implemented by prvQueueReceiveTask() in main_blinky.c. It blocks on queue reads, unblocking and toggling an LED each time the message from the queue send task is received. The queue send task sends to the queue every 200 milliseconds, so the queue receive task leaves the Blocked state and toggles the LED every 200 milliseconds.
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0 then main() calls main_full(). main_full() creates a comprehensive test and demo application that demonstrates: The created tasks are from the set of standard demo tasks. Standard demo tasks are used by all FreeRTOS port demo applications and have no specific functionality. They are used to demonstrate how to use the FreeRTOS API, and to test the RTOS port.
A 'check' task is created to periodically inspect the standard demo tasks in order to ensure all the tasks are functioning as expected. The check task also toggles an LED to give a visual feedback of the system status. If the LED is toggling every 3 seconds, then the check task has not discovered any problems. If the LED is toggling every 200 milliseconds, then the check task has discovered a problem in one or more tasks..
Building and executing the demo application - Atmel Studio
  1. Open the project file FreeRTOS/Demo/CORTEX_M7_SAMV71_Xplained_AtmelStudio/RTOSDemo.atsln or FreeRTOS/Demo/CORTEX_M7_SAME70_Xplained_AtmelStudio/RTOSDemo.atsln from within the Atmel Studio IDE.
  3. Ensure the target hardware is connected to the host computer using a suitable debugger interface - the demo was developed and debugged using a J-Link; the Edge debug interface built onto the target hardware can also be used.
  4. Select 'Build Solution' from the IDE's 'Build' menu, the RTOS demo project should build without any errors or warnings.
  5. After the build completes, select 'Start Debugging and Break' from the IDE's 'Debug' menu to program the Cortex-M7 microcontroller, start a debug session, and have the debugger break on entry into the main() function.
  1. Open FreeRTOS/Demo/CORTEX_M7_SAMV71_Xplained_IAR_Keil/RTOSDemo.eww from within the IAR Embedded Workbench IDE.
  3. Ensure the target hardware is connected to the host computer using a suitable debugger interface - the demo was developed and debugged using a J-Link.
  4. Select 'Rebuild All' from the IDE's 'Project' menu, the RTOSDemo project should build without any errors or warnings.
  5. After the build completes, select 'Download and Debug' from the IDE's 'Project' menu to program the Cortex-M7 microcontroller, start a debug session, and have the debugger break on entry into the main() function.
Building and executing the demo application - Keil
  1. Open the project file FreeRTOS/Demo/CORTEX_M7_SAMV71_Xplained_IAR_Keil/RTOSDemo.uvprojx from within the Keil uVision IDE.
  4. Select 'Build Target' from the IDE's 'Project' menu, the RTOSDemo project should build without any errors or warnings.
  5. After the build completes, select 'Start/Stop Debug Session' from the IDE's 'Debug' menu to program the Cortex-M7 microcontroller, start a debug session, and have the debugger break on entry into the main() function.
Configuration items specific to this demo are contained in the file FreeRTOS/Demo/CORTEX_M7_SAMV71_Xplained_IAR_Keil/FreeRTOSConfig.h or FreeRTOS/Demo/CORTEX_M7_SAME70_Xplained_IAR_Keil/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
    Whereas configKERNEL_INTERRUPT_PRIORITY and configMAX_SYSCALL_INTERRUPT_PRIORITY are full eight bit un-shifted values, defined to be used as raw numbers directly in the ARM Cortex-M7 NVIC registers, configLIBRARY_LOWEST_INTERRUPT_PRIORITY and configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY are equivalents that are defined using just the 3 priority bits implemented in the SAMV7 and SAME7 NVIC. These values are provided because the CMSIS library function NVIC_SetPriority() requires the un-shifted 3 bit format.
The lowest priority on a ARM Cortex-M core is in fact 255 - however, different ARM Cortex-M microcontroller manufacturers implement a different number of priority bits and supply library functions that expect priorities to be specified in different ways. For example, on Atmel SAMV7/SAME7 ARM Cortex-M7 microcontrollers, the lowest priority you can specify is in fact 7 - this is defined by the constant configLIBRARY_LOWEST_INTERRUPT_PRIORITY in FreeRTOSConfig.h. The highest priority that can be assigned is always zero.
