Updated Mar 2025
Hook Functions
Idle Hook Function
The idle task can optionally call an application defined hook (or callback) function - the idle hook. The idle task runs at the very lowest priority, so such an idle hook function will only get executed when there are no tasks of higher priority that are able to run. This makes the idle hook function an ideal place to put the processor into a low power state - providing an automatic power saving whenever there is no processing to be performed.
The idle hook will only get called if configUSE_IDLE_HOOK is set to 1 within FreeRTOSConfig.h. When this is set the application must provide the hook function with the following prototype:
1void vApplicationIdleHook( void );
The idle hook is called repeatedly as long as the idle task is running. It is paramount that the idle hook function does not call any API functions that could cause it to block. Also, if the application makes use of the vTaskDelete() API function then the idle task hook must be allowed to periodically return (this is because the idle task is responsible for cleaning up the resources that were allocated by the RTOS kernel to the task that has been deleted).
Tick Hook Function
The tick interrupt can optionally call an application defined hook (or callback) function - the tick hook. The tick hook provides a convenient place to implement timer functionality.
The tick hook will only get called if configUSE_TICK_HOOK is set to 1 within FreeRTOSConfig.h. When this is set the application must provide the hook function with the following prototype:
1void vApplicationTickHook( void );
vApplicationTickHook() executes from within an ISR so must be very short, not use much stack, and not call any API functions that don't end in "FromISR" or "FROM_ISR".
See the demo application file crhook.cexternal_link for an example of how to use a tick hook.
Malloc Failed Hook Function
The memory allocation schemes implemented by heap_1.c, heap_2.c, heap_3.c, heap_4.c and heap_5.c can optionally include a malloc() failure hook (or callback) function that can be configured to get called if pvPortMalloc() ever returns NULL.
Defining the malloc() failure hook will help identify problems caused by lack of heap memory - especially when a call to pvPortMalloc() fails within an API function.
The malloc failed hook will only get called if configUSE_MALLOC_FAILED_HOOK is set to 1 within FreeRTOSConfig.h. When this is set the application must provide the hook function with the following prototype:
1void vApplicationMallocFailedHook( void );
Stack Overflow Hook Function
See the Stack Overflow Protection page for details.
Daemon Task Startup Hook
The RTOS daemon task is the same as the Timer Service Task. Sometimes it is referred to as the daemon task because the task is now used for more than just servicing timers.
If configUSE_DAEMON_TASK_STARTUP_HOOK is set to 1 in FreeRTOSConfig.h then the Daemon Task Startup Hook will be called as soon as the Daemon Task starts executing for the first time. This is useful if the application includes initialisation code that would benefit from executing after the scheduler has been started, which allows the initialisation code to make use of the RTOS functionality.
If configUSE_DAEMON_TASK_STARTUP_HOOK is set to 1 then the application writer must provide an implementation of the Daemon Task startup hook function with the following name an prototype.
1void vApplicationDaemonTaskStartupHook( void );
