Updated Mar 2025
vTaskGetInfo()
[Task Utilities]
task.h
1void vTaskGetInfo( TaskHandle_t xTask,
2 TaskStatus_t *pxTaskStatus,
3 BaseType_t xGetFreeStackSpace,
4 eTaskState eState );
configUSE_TRACE_FACILITY
must be defined as 1 in FreeRTOSConfig.h for
vTaskGetInfo()
to be available.
Whereas uxTaskGetSystemState() populates a TaskStatus_t structure for each task in the system,
vTaskGetInfo()
populates a
TaskStatus_t
structures for just a single task. The
TaskStatus_t
structure contains, among other things, members for the task handle, task name, task priority, task state, and total amount of run time consumed by the task.
NOTE: This function is intended for debugging use only as its use results in the scheduler remaining suspended for an extended period.
  • xTask
    The handle of the task being queried. Setting xTask to NULL will return information on the calling task.
  • pxTaskStatus
    The
    TaskStatus_t
    structure pointed to by
    pxTaskStatus
    will be filled with information about the task referenced by the handle passed in the
    xTask
    parameter.
  • xGetFreeStackSpace
    The
    TaskStatus_t
    structure contains a member to report the stack high water mark of the task being queried. The stack high water mark is the minimum amount of stack space that has ever existed, so the closer the number is to zero the closer the task has come to overflowing its stack. Calculating the stack high water mark takes a relatively long time, and can make the system temporarily unresponsive - so the
    xGetFreeStackSpace
    parameter is provided to allow the high water mark checking to be skipped. The high watermark value will only be written to the
    TaskStatus_t
    structure if
    xGetFreeStackSpace
    is not set to
    pdFALSE
  • eState
    The
    TaskStatus_t
    structure contains a member to report the state of the task being queried. Obtaining the task state is not as fast as a simple assignment - so the
    eState
    parameter is provided to allow the state information to be omitted from the
    TaskStatus_t
    structure. To obtain state information then set eState to
    eInvalid
    - otherwise the value passed in
    eState
    will be reported as the task state in the
    TaskStatus_t
    structure.
1void vAFunction( void )
2{
3 TaskHandle_t xHandle;
4 TaskStatus_t xTaskDetails;
5
6 /* Obtain the handle of a task from its name. */
7 xHandle = xTaskGetHandle( "Task_Name" );
8
9 /* Check the handle is not NULL. */
10 configASSERT( xHandle );
11
12 /* Use the handle to obtain further information about the task. */
13 vTaskGetInfo( /* The handle of the task being queried. */
14 xHandle,
15 /* The TaskStatus_t structure to complete with information
16 on xTask. */
17 &xTaskDetails,
18 /* Include the stack high water mark value in the
19 TaskStatus_t structure. */
20 pdTRUE,
21 /* Include the task state in the TaskStatus_t structure. */
22 eInvalid );
23}
The TaskStatus_t definition
1typedef struct xTASK_STATUS
2{
3 /* The handle of the task to which the rest of the information in the
4 structure relates. */
5 TaskHandle_t xHandle;
6
7 /* A pointer to the task's name. This value will be invalid if the task was
8 deleted since the structure was populated! */
9 const char *pcTaskName;
10
11 /* A number unique to the task. */
12 UBaseType_t xTaskNumber;
13
14 /* The state in which the task existed when the structure was populated. */
15 eTaskState eCurrentState;
16
17 /* The priority at which the task was running (may be inherited) when the
18 structure was populated. */
19 UBaseType_t uxCurrentPriority;
20
21 /* The priority to which the task will return if the task's current priority
22 has been inherited to avoid unbounded priority inversion when obtaining a
23 mutex. Only valid if configUSE_MUTEXES is defined as 1 in
24 FreeRTOSConfig.h. */
25 UBaseType_t uxBasePriority;
26
27 /* The total run time allocated to the task so far, as defined by the run
28 time stats clock. Only valid when configGENERATE_RUN_TIME_STATS is
29 defined as 1 in FreeRTOSConfig.h. */
30 unsigned long ulRunTimeCounter;
31
32 /* Points to the lowest address of the task's stack area. */
33 StackType_t *pxStackBase;
34
35 #if ( configRECORD_STACK_HIGH_ADDRESS == 1 )
36 /* Points to the top address of the task's stack area. */
37 StackType_t * pxTopOfStack;
38
39 /* Points to the bottom address of the task's stack area. */
40 StackType_t * pxEndOfStack;
41 #endif
42
43 /* The minimum amount of stack space that has remained for the task since
44 the task was created. The closer this value is to zero the closer the task
45 has come to overflowing its stack. */
46 configSTACK_DEPTH_TYPE usStackHighWaterMark;
47} TaskStatus_t;
