xMessageBufferGetStaticBuffers()
[RTOS Message Buffer API]
message_buffer.h
1BaseType_t xMessageBufferGetStaticBuffers( MessageBufferHandle_t xMessageBuffer,
2 uint8_t ** ppucMessageBufferStorageArea,
3 StaticMessageBuffer_t ** ppxStaticMessageBuffer );
Retrieve pointers to a statically created message buffer's data structure buffer and storage area buffer. These are the same buffers that are supplied at the time of creation.
  • xMessageBuffer
    The message buffer whose data structure buffer and storage area buffer will be retrieved.
  • ppucMessageBufferStorageArea
    Used to return a pointer to the message buffer's storage area buffer.
  • ppxStaticMessageBuffer
    Used to return a pointer to the message buffer's data structure buffer.
