Updated Apr 2025
xTimerDelete
1 BaseType_t xTimerDelete( TimerHandle_t xTimer,
2 TickType_t xBlockTime );
xTimerDelete() deletes a timer that was previously created using the xTimerCreate() API function. Note, when deleting a statically allocated timer, its static memory cannot be reused until that timer is indicated inactive by xTimerIsTimerActive().
The configUSE_TIMERS configuration constant must be set to 1 for xTimerDelete() to be available.
  • xTimer
    The handle of the timer being deleted.
  • xBlockTime
    Specifies the time, in ticks, that the calling task should be held in the Blocked state to wait for the delete command to be successfully sent to the timer command queue, should the queue already be full when xTimerDelete() was called. xBlockTime is ignored if xTimerDelete() is called before the RTOS scheduler is started.
  • pdFAIL will be returned if the delete command could not be sent to the timer command queue even after xBlockTime ticks had passed.
  • pdPASS will be returned if the command was successfully sent to the timer command queue. When the command is actually processed will depend on the priority of the timer service/daemon task relative to other tasks in the system. The timer service/daemon task priority is set by the configTIMER_TASK_PRIORITY configuration constant.
See the example on the xTimerChangePeriod() documentation page.
