Updated Mar 2025
xTimerGetExpiryTime
1 TickType_t xTimerGetExpiryTime( TimerHandle_t xTimer );
Returns the time at which the software timer will expire, which is the time at which the timer's callback function will execute.
If the value returned by xTimerGetExpiryTime() is less than the current time then the timer will expire after the tick count has overflowed and wrapped back to 0. Overflows are handled in the RTOS implementation itself, so a timer's callback function will execute at the correct time whether it is before or after the tick count overflows.
xTimer
The timer being queried.
If the timer referenced by xTimer is active, then the time at which the timer will next expire is returned (which may be after the current tick count has overflowed, see the notes above).
If the timer referenced by xTimer is not active then the return value is undefined.
1static void prvAFunction( TimerHandle_t xTimer )2{3TickType_t xRemainingTime;45 /* Calculate the time that remains before the timer referenced by xTimer6 expires. TickType_t is an unsigned type, so the subtraction will result in7 the correct answer even if the timer will not expire until after the tick8 count has overflowed. */9 xRemainingTime = xTimerGetExpiryTime( xTimer ) - xTaskGetTickCount();10}
