Updated Apr 2025
FreeRTOS LTS Libraries
NOTE: FreeRTOS 202406.01 LTS libraries are now available in the FreeRTOS-LTS GitHub repository.
See What’s New.
AWS also offers the FreeRTOS Extended Maintenance Plan (EMP) that provides you with security patches and critical
bug fixes on your chosen FreeRTOS LTS version for up to an additional 10 years. Visit the
EMP page on the AWS site for details.
FreeRTOS LTS libraries are also available from partner toolchains. See the blog post.
**Note:**You can find example projects for the libraries included in this bundle in the primary FreeRTOS download. Refer to the FAQ for details.
Download the previous version:
LTS 202210 Libraries
Upgrading to version 202406.xx of FreeRTOS LTS from the previous version
Refer to the Upgrading to FreeRTOS202406-LTS section in the FreeRTOS-LTS repository for information about upgrading from previous version.
LTS Status
The following table lists the libraries that are part of FreeRTOS 202406 LTS. All meet the LTS modularity and Code Quality Checklist requirements other than the kernel and TCP stack, both of which still comply with their original quality requirements.
Last Updated: July 16, 2024
Library | Version | Maintained at least until |
FreeRTOS Kernel | 11.1.0 | June 30, 2026 |
FreeRTOS-Plus-TCP | 4.2.2 | June 30, 2026 |
coreMQTT | 2.3.1 | June 30, 2026 |
coreHTTP | 3.1.1 | June 30, 2026 |
corePKCS11 | 3.6.1 | June 30, 2026 |
coreJSON | 3.3.0 | June 30, 2026 |
coreSNTP | 1.3.1 | June 30, 2026 |
FreeRTOS-Cellular-Interface | 1.4.0 | June 30, 2026 |
backoffAlgorithm | 1.4.1 | June 30, 2026 |
AWS IoT SigV4 | 1.3.0 | June 30, 2026 |
AWS IoT Device Shadow | 1.4.1 | June 30, 2026 |
AWS IoT Device Defender | 1.4.0 | June 30, 2026 |
AWS IoT Jobs | 1.5.1 | June 30, 2026 |
AWS IoT Fleet Provisioning | 1.2.1 | June 30, 2026 |
AWS IoT MQTT File Streams | 1.1.0 | June 30, 2026 |
For information on library versions for the previous LTS version, see
the FreeRTOS 202210.xx-LTS repository on GitHub.
FreeRTOS LTS Patches
For the latest information, subscribe to GitHub Notifications by watching
the FreeRTOS LTS repository.
Patch Version | Updates | Post |
202406.01 LTS | Include fixes for coreMQTT (v2.3.1) and FreeRTOS-Plus-TCP (V4.2.2). | Changelog |
202210.01 LTS | Includes critical fixes for the coreMQTT (V2.1.1) and FreeRTOS kernel (V10.5.1). | Changelog |
202012.05 LTS | Includes critical fixes for the FreeRTOS kernel (10.4.3-LTS-Patch-3). | Release notes |
202012.05 LTS | Includes security patches for the FreeRTOS kernel (10.4.3-LTS-Patch-3). | Security Updates |
202012.04 LTS | Includes critical bug fixes for the FreeRTOS-Plus-TCP library (2.3.2-LTS-Patch-2). | Release notes |
202012.03 LTS | Includes security patches for the FreeRTOS kernel (10.4.3-LTS-Patch-2). | Security Updates |
202012.02 LTS | Includes security patches for the FreeRTOS kernel (10.4.3-LTS-Patch-1) and TCP libraries (V2.3.2-LTS-Patch-1). | Security Updates |
202012.01 LTS | Added AWS IoT OTA, AWS Device Defender, and AWS IoT Jobs library to 202012.00 LTS | Blog Post |
LTS Code Quality Checklist
# | Category | Checks |
1 | Complexity Score | Functions shall have a GNU Complexity |
2 | Coding Standard | Functions shall comply with the MISRA 2012 coding standard. |
3 | Static Checking | Functions shall pass Coverity |
4 | APSEC review and pentest | Libraries must pass AWS security review. |
5 | Code Testing, including memory safety proofs | The code shall have extensive unit and function tests, with Gcov reports detailing test coverage, as well as CBMC memory safety proofs. |
6 | Requirements Documentation | Libraries shall have documented requirements, which may include resource, dependency, and porting requirements (as applicable). |
7 | Design Documentation | Libraries shall have design documentation, including application and cloud interface, state machines, and synchronization (as applicable). |
8 | Compiler Warning | The code shall compile with GCC using the -Wall and -Wextra command line options without generating compiler warnings. |
