FreeRTOS_SetEndPointConfiguration()
FreeRTOS_IP.h
1void FreeRTOS_SetEndPointConfiguration( const uint32_t * pulIPAddress,2 const uint32_t * pulNetMask,3 const uint32_t * pulGatewayAddress,4 const uint32_t * pulDNSServerAddress,5 struct xNetworkEndPoint * pxEndPoint )
Set the current IPv4 network address configuration of the TCP/IP stack for a given IPv4 endpoint. Only non-NULL pointers will be used.
pulIPAddress
Used to set the IP address being used by the IP stack. The IP address is represented as a 32-bit number in network byte order.
pulNetMask
Used to set the net mask being used by the IP stack. The net mask is represented as a 32-bit number in network byte order.
pulGatewayAddress
Used to set the IP address of the gateway being used by the IP stack. The IP address is represented as a 32-bit number in network byte order.
pulDNSServerAddress
Used to set the IP address of the DNS server being used by the IP stack. The IP address is represented as a 32-bit number in network byte order.
pxEndPoint
The IPv4 end-point which is being set with the configuration.
No return value.
