Updated Mar 2025
Reference: errno values
Standard API errno Values
[FreeRTOS-Plus-FAT Standard API Reference]
The FreeRTOS-Plus-FAT file system's standard API uses the same errno values as used by the standard C library. File related functions in standard C library return 0 for pass, and -1 for fail. If -1 is returned then the reason for the failure is stored in a variable called errno, which must be inspected separately.
Similarly, FreeRTOS-Plus-FAT's standard API returns 0 for and -1 for fail, and maintains an errno variable for each RTOS task. A task can retrieve its errno value by calling stdioGET_ERRNO(). The error codes returned by stdioGET_ERRNO() are defined in <projdefs.h> files and are listed below.
Value | Constant | Description |
0 | pdFREERTOS_ERRNO_NONE | No such file or directory |
2 | pdFREERTOS_ERRNO_ENOENT | No such file or directory |
5 | pdFREERTOS_ERRNO_EIO | I/O error |
6 | pdFREERTOS_ERRNO_ENXIO | No such device or address |
9 | pdFREERTOS_ERRNO_EBADF | Bad file number |
11 | pdFREERTOS_ERRNO_EAGAIN | No more processes |
11 | pdFREERTOS_ERRNO_EWOULDBLOCK | Operation would block |
12 | pdFREERTOS_ERRNO_ENOMEM | Not enough core |
13 | pdFREERTOS_ERRNO_EACCES | Permission denied |
14 | pdFREERTOS_ERRNO_EFAULT | Bad address |
16 | pdFREERTOS_ERRNO_EBUSY | Mount device busy |
17 | pdFREERTOS_ERRNO_EEXIST | File exists |
18 | pdFREERTOS_ERRNO_EXDEV | Cross-device link |
19 | pdFREERTOS_ERRNO_ENODEV | No such device |
20 | pdFREERTOS_ERRNO_ENOTDIR | Not a directory |
21 | pdFREERTOS_ERRNO_EISDIR | Is a directory |
22 | pdFREERTOS_ERRNO_EINVAL | Invalid argument |
28 | pdFREERTOS_ERRNO_ENOSPC | No space left on device |
29 | pdFREERTOS_ERRNO_ESPIPE | Illegal seek |
30 | pdFREERTOS_ERRNO_EROFS | Read only file system |
42 | pdFREERTOS_ERRNO_EUNATCH | Protocol driver not attached |
50 | pdFREERTOS_ERRNO_EBADE | Invalid exchange |
79 | pdFREERTOS_ERRNO_EFTYPE | Inappropriate file type or format |
89 | pdFREERTOS_ERRNO_ENMFILE | No more files |
90 | pdFREERTOS_ERRNO_ENOTEMPTY | Directory not empty |
91 | pdFREERTOS_ERRNO_ENAMETOOLONG | File or path name too long |
95 | pdFREERTOS_ERRNO_EOPNOTSUPP | Operation not supported on transport endpoint |
105 | pdFREERTOS_ERRNO_ENOBUFS | No buffer space available |
109 | pdFREERTOS_ERRNO_ENOPROTOOPT | Protocol not available |
112 | pdFREERTOS_ERRNO_EADDRINUSE | Address already in use |
116 | pdFREERTOS_ERRNO_ETIMEDOUT | Connection timed out |
119 | pdFREERTOS_ERRNO_EINPROGRESS | Connection already in progress |
120 | pdFREERTOS_ERRNO_EALREADY | Socket already connected |
125 | pdFREERTOS_ERRNO_EADDRNOTAVAIL | Address not available |
127 | pdFREERTOS_ERRNO_EISCONN | Socket is already connected |
128 | pdFREERTOS_ERRNO_ENOTCONN | Socket is not connected |
135 | pdFREERTOS_ERRNO_ENOMEDIUM | No medium inserted |
138 | pdFREERTOS_ERRNO_EILSEQ | An invalid UTF-16 sequence was encountered |
140 | pdFREERTOS_ERRNO_ECANCELED | Operation cancelled |
Native API errno Values
[FreeRTOS-Plus-FAT Native API Reference]
The file system's native API has a more sophisticated error code system, and returns error codes directly from its API functions. Error codes used by native APIs are defined in <ff_error.h>.
