Updated May 2025
MCUBoot Demo
NOTE: The following instructions assume a Linux or Windows Subsystem for Linux (WSL) host. WSL installation
and setup instructions can be found here.
The demo currently supports the esp32 architecture. The following instructions are specific to this hardware.
The demo consists of MCUBoot booting an application which first disables a bootloader watchdog timer, prints its version number, then confirms itself so it won't be reverted if it's an update. The app proceeds to periodically print "hello world".
The demo also details the application signing and upgrade process, and provides a porting guide for
implementing on other SoCs. Finally, use of is
demonstrated for retrieving image
diagnostics, modifying/uploading images, and triggering other board functions from your host PC.
Building and Uploading The Bootloader
Download then enter the repo directory.
1git clone --recurse-submodules https://github.com/FreeRTOS/Lab-Project-FreeRTOS-MCUBoot.git2cd Lab-Project-FreeRTOS-MCUBoot -
Apply the patches required for the bootloader and application.
1git -C lib/mcuboot apply ../../patches/mcuboot.patch2git -C lib/mcuboot/boot/espressif/hal/esp-idf/ apply ../../../../../../patches/esp-idf.patch -
Configure the ESP-IDF tools, then enter the bootloader project directory.
1./lib/mcuboot/boot/espressif/hal/esp-idf/install.sh2source lib/mcuboot/boot/espressif/hal/esp-idf/export.sh3cd proj/espressif/esp32/bootloader -
Connect your esp32 and identify it's USB descriptor (for example '/dev/ttyUSB0'), then set this ID.
1export ESPPORT=/dev/<USB> -
Decide which, if any, cryptographic verification you want from the following choices:
- ecdsa-p256
- rsa-2048
- rsa-3072
If you want cryptographic image verification, generate the build files as follows, setting
to be exactly equal to one of the choices above.SIGNING_SCHEME1cmake -GNinja -DSIGNING_SCHEME=ecdsa-p256 -B buildThis will generate a private key, of the selected scheme, in the bootloader project directory. The name defaults as
. The private key will be used for signing the application images. Meanwhile, the cmake targets take care of embedding the public key in the bootloader, so it can verify the images.mcuboot-private-key.pemIf you don't want cryptographic image verfication you can omit the
definition in the command above.SIGNING_SCHEME -
Finally, to upload the bootloader to the board, run the following.
1cmake --build build --target mcuboot-flash
Building and Uploading The Application
After building and flashing the bootloader, proceed with the following. If you're in a new shell session you likely need to re-run the steps above for configuring the IDF toolchain and set
ESPPORT
Enter the application project directory.
1cd proj/espressif/esp32/app -
Similarly, when generating build files for the application, you must set
to match whichever scheme was selected for the Bootloader. Moreover, you must setSIGNING_SCHEMEto point to the private key generated by the bootloader project. If you opted out of cryptographic image verification in the bootloader, you must similarly omit theKEY_PATHandSIGNING_SCHEMEdefinitions below. Finally, you can set the application version by addingKEY_PATHto the command below.-DAPP_VERSION=X.Y.Z1cmake -DSIGNING_SCHEME=ecdsa-p256 -DKEY_PATH=../bootloader/mcuboot-private-key.pem -GNinja -B build -
Build the application.
1cmake --build build --target app -
There are two options for uploading the image: directly flashing to the primary image slot, or flashing to the secondary image slot which prompts an upgrade on the subsequent boot if the image has a newer version than that of the primary image. If you don't yet have an image in the primary slot, then directly upload the image there:
1cmake --build build --target mcuboot-app-flashWhen queuing an upgrade, if the secondary image has a newer version than the primary image, the two images will be swapped and the update image will be tentatively booted, and revert upon the subsequent boot if the update image does not confirm itself. Hence the application calls
so that it persists as the primary image. Updated images that don't do this will be reverted. To upgrade the image, perform the following:boot_set_confirmed1cmake --build build --target mcuboot-app-upgrade -
Finally, view the output from the device.
1idf.py monitor
Debugging The Application
Configure the ESP-IDF tools in two separate shell sessions using the following commands in each:
1./lib/mcuboot/boot/espressif/hal/esp-idf/install.sh2source lib/mcuboot/boot/espressif/hal/esp-idf/export.sh -
In one terminal, enter the app directory and start the OpenOCD server.
1cd proj/espressif/esp32/app2idf.py openocd -
In the other terminal, enter the app directory and start the GDB session.
1cd proj/espressif/esp32/app2idf.py gdb
Serial Boot Mode and MCUMGR Interface
Serial boot mode is enabled by default, but can be disabled by setting
MCUBOOT_SERIAL
mcuboot_config.h
lib/mcuboot/boot/freertos
GPIO 5
mcumgr
mcumgr
MCUMGR will communicate with the board via UART pins which, for this demo, are set as
GPIO 27 (RX)
GPIO 26 (TX)
Define a connection for
mcumgr
1mcumgr conn add esp type="serial" connstring="dev=/dev/<USB>,baud=115200,mtu=256"
Tie the boot serial pin to VCC, then reset the board to enter serial boot recovery mode. The board will log that it has entered serial boot mode. You may proceed with the
mcumgr
To list images on the device:
1mcumgr -c esp image list
To upload an image:
1mcumgr -c esp image upload /path/to/mcuboot-image.bin
This expects a signed/formatted MCUBoot image. After building the application, this can be found in its build directory as
build/mcuboot-app.bin
To reset the board:
1mcumgr -c esp reset
