STM32 Connectivity Line ARM Cortex-M3 demo
[Embedded Ethernet Examples]
IMPORTANT! Notes on using the ST ARM Cortex-M3 Web Server Demo
The CrossWorks workspace for the STM32F107 demo is located in the FreeRTOS/Demo/CORTEX_STM32F107_GCC_Rowley directory.
web server configuration
Ensure that jumper JP4 is set so that JP4 pins 1 and 2 are shorted - this routes the output of the external 25MHz crystal to the PHY. Jumpers JP3, JP11, JP12 and JP13 need to be shorting pins 2 and 3, which should be the default setting.
Connect the STM3210C evaluation board to a computer running a web browser either directly using a point to point (crossover) cable, or via an Ethernet switch using a standard Ethernet cable.
The IP address used by the demo is set by the constants configIP_ADDR0 to configIP_ADDR3 within the file FreeRTOS/Demo/CORTEX_STM32F107_GCC_Rowley/FreeRTOSConfig.h. The MAC address and net mask are configured within the same header file.
The IP addresses used by the web browser computer and the STM32 development board must be compatible. This can be ensured by making the first three octets of both IP addresses identical. For example, if the web browser computer uses IP address 192.168.100.1, then the development board can be given any address in the range 192.168.100.2 to 192.168.100.254 (barring any addresses already present on the network).
  1. Open the FreeRTOS/Demo/CORTEX_STM32F107_GCC_Rowley/RTOSDemo.hzp solution from within the CrossStudio IDE.
  2. Select the appropriate build configuration - either "THUMB Flash Debug" if you wish to debug the application, or "THUMB Flash Release" if you wish to run the application stand alone (without the debugger). Note that the "Thumb Flash Debug" configuration can only be used in combination with the debugger - it can not be used to execute the demo simply by resetting the board.
  3. Select "Build RTOSDemo" from the "Build" menu - the solution should build with no errors or warnings.
  4. Connect your chosen JTAG interface between the host computer and the target hardware (the project was developed using a J-Link), apply power to the target, then connect to the target using the appropriate item from the IDE "Target" menu.
  5. Select "Start Debugging" from the "Debug" menu. The microcontroller Flash memory will be programmed and the debugger will break at main.
The ST peripheral library
Please note that the peripheral library utilised by the demo application is neither re-entrant nor event driven.
During its initialisation, the demo application accesses IO port configuration from within more than one task. This raises the possibility of problems related to re-entrancy (or lack of it). No attempt is made to guard against this. If this proves problematic then place the initialisation library calls inside critical sections.
The LCD driver uses a polled SPI interface. Currently the LCD gatekeeper task is configured to execute at a medium priority - resulting in lower priority tasks not getting any processing time while the SPI interface is being polled. The task can be configured to execute at the lowest priority, but this results in visibly slower LCD updates. A much more efficient solution would be to re-implement the driver to make use of the DMA and be event driven.
The demo application creates 30 tasks prior to starting the RTOS scheduler. These tasks consist predominantly of the standard demo application tasks (see the demo application section for details of the individual tasks). Their only purpose is to test the RTOS kernel port and provide a demonstration of how to use the various API functions.
    A 20KHz periodic interrupt is generated using a timer to demonstrate the use of the 'configKERNEL_INTERRUPT_PRIORITY' and 'configMAX_SYSCALL_INTERRUPT_PRIORITY' configuration constants. The interrupt service routine measures the number of processor clocks that occur between each interrupt - and in so doing measures the jitter in the interrupt timing. The maximum measured jitter time is latched in the ulMaxJitter variable, and displayed on the LCD display by the 'Check' task as described below. The fast interrupt is configured and handled in the timertest.c source file. This demonstrates how the RTOS kernel can be configured so as to have no impact on higher priority interrupt processing.
    The ARM Cortex-M3 core has the ability to hasten the entry into an interrupt service routine (and therefore reduce latency) by up to 8 cycles should a high priority interrupt occur while a lower priority interrupt is already being serviced. The measured jitter time should therefore be no more than about 8 clock cycles.
  • LCD task
    This only executes every five seconds. Its main function is to check that all the standard demo tasks are still operational. Should any unexpected behaviour be discovered within a standard demo task the 'check' function will write an error to the LCD (via the LCD task). If all the demo tasks are executing with their expected behaviour then the check task writes PASS and the maximum measured jitter time in nano seconds to the LCD (again via the LCD task). The jitter time is measured within the high priority interrupt test as described above.
  • uIP task
  • The 'check' function will write "PASS" and the maximum measured jitter time to the LCD every 5 seconds.
  • LEDs 1, 2 and 3 are under the control of the standard 'flash' tasks. Each will toggle at a fixed but different frequency.
Served Web Pages
The served IO page
The IO page provides a simple interface that permits data to be sent to LED 4 and LCD on the development board.
The check box permits the state of LED 4 to be set and queried. The text box can be used to write a message to the LCD, but does not query the text currently being display. Changes are sent to the target hardware by clicking the "Update IO" button.
Configuration items specific to these demos are contained in FreeRTOS/Demo/CORTEX_STM32F107_GCC_Rowley/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
Unlike most ports, interrupt service routines that cause a context switch have no special requirements and can be written as per the compiler documentation. The macro portEND_SWITCHING_ISR() can be used to request a context switch from within an ISR. An example interrupt service routine called vMAC_ISR() is provided in FreeRTOS/Demo/CORTEX_STM32F107_GCC_Rowley/webserver/emac.c. This should be used as a reference example.
Set the definition configUSE_PREEMPTION within FreeRTOS/Demo/CORTEX_STM32F107_GCC_Rowley/FreeRTOSConfig.h to 1 to use pre-emption or 0 to use co-operative.
Latest News
Careers
FreeRTOS Partners
Cadence Tensilica Cortes
Espressif ESP32
IAR Partner
Mediatek
Renesas
RISC-V
SiFIve RISC-V
OpenRTOS and SafeRTOS
