FreeRTOS SMP:
Embedded World track keynote:
xTimerIsTimerActive
 BaseType_t xTimerIsTimerActive( TimerHandle_t xTimer );
Queries a software timer to see if it is active or dormant.
A timer will be dormant if:
  1. It has been created but not started, or
  2. It is an expired one-shot timer that has not been restarted.
Timers are created in the dormant state. The xTimerStart(), xTimerReset(), xTimerStartFromISR(), xTimerResetFromISR(), xTimerChangePeriod() and xTimerChangePeriodFromISR() API functions can all be used to transition a timer into the active state.
pdFALSE will be returned if the timer is dormant. A value other than pdFALSE will be returned if the timer is active.
 /* This function assumes xTimer has already
 been created. */
         /* xTimer is active, do something. */
         /* xTimer is not active, do something else. */
