Renesas RX62N Demo using GNURX (GCC) and the HEW IDE
[Embedded Ethernet Examples]
This is the documentation page for the Renesas RX62N FreeRTOS port that makes use of the GNURX GCC tools, and the Renesas HEW IDE. The FreeRTOS download includes demo applications for two standard development boards, the Renesas RX62N Starter Kit (RSK) and the Renesas RX62N Demonstration Kit (RDK) boards.
Note that GNURX version 10.03 or higher is required.
Demo applications are also available for the IAR and Renesas compilers.
The demo application includes an example web server that uses a modified version of Adam Dunkels open source uIP tiny TCP/IP stack. Code-named FreeTCPIP, the modifications allow for higher throughput than that achievable with the original code. CGI scripting is used to serve pages that include both RTOS and TCP/IP run time information. uIP is licensed separately from FreeRTOS. Users must familiarise themselves with the uIP licence, which is included at the top of each uIP source file.
IMPORTANT! Notes on using the GCC RX62N port and web server demo
The HEW workspaces for the RDK and RSK boards are called RX600_RX62N_RDK_GNURX.hws and RX600_RX62N_RSK_GNURX.hws and can be located in the FreeRTOS/Demo/RX600_RX62N-RDK_GNURX and FreeRTOS/Demo/RX600_RX62N-RSK_GNURX directories of the main FreeRTOS download respectively.
RX62N Demo Application
The HEW workspace contains three build configurations:
Blinky This is a very simple example that just creates two tasks. The tasks communicate via a queue, with an LED being toggled each time an expected value is received from the queue. The Blinky build configuration includes main-blinky.c, the other two build configurations use main-full.c.
Debug This is a much more comprehensive demo that creates nearly 50 demo tasks. A further two tasks are then repeatedly creates and deleted as the application runs. The tasks consist mainly of the standard demo tasks - which don't perform any particular functionality other than testing the port (including interrupt nesting) and demonstrating how the FreeRTOS API is used. Information on additional tasks that are created is provided immediately below this table.
Debug_with_optimisation This is similar to the 'Debug' configuration, but adds a high frequency timer test and tests that the tasks and tests execute correctly when the optimiser is switched on.
  • Check task
    This only executes every five seconds but has the highest priority to ensure it gets CPU time. Its main function is to check that all the standard demo tasks are still operational. The check function maintains a status string that can be viewed at the very bottom of the "Task Stats" page served by the integrated web server. It also toggles LED5 if using the RSK, or LED9 if using the RDK. If the LED controlled by the check task is toggling once every five seconds then all the demo tasks are executing without ever reporting an error. If the toggle frequency increases to once every 200ms then an error has been detected in at least one task.
  • uIP task
    This is the task that runs the TCP/IP stack. All network related processing and communication is performed in this task, making the TCP/IP Flash footprint extremely small when compared to other embedded TCP/IP stacks.
  • Reg test tasks
    These two tasks fill the microcontroller registers with known values before checking that each register still contains the written and expected value. Each of the two tasks use different known values. The tasks run with very low priority so will get preempted very often. If a register ever contains an unexpected value then an error has occurred - probably in the context switching or interrupt mechanism. The reg test tasks write directly into registers and are therefore written in assembly code.
  • High frequency timer test
    This test configures a timer to generate an interrupt at 20KHz. The interrupt priority is above configMAX_SYSCALL_INTERRUPT_PRIORITY so should not be effected by anything else the RTOS kernel is doing. The jitter measured in the interrupt timing is displayed at the bottom of the "Run Time Stats" page served by the integrated web server.
Web server configuration
  2. Before opening the project - if using an RSK development board connect the RSK to the host computer using an E1 JTAG interface (provided as part of the RSK) then apply power. If using an RDK development board just connect the micro USB socket on the RDK that is marked J-Link to the host computer - no separate power is needed. The HEW will attempt to connect to the chosen development board as the project is opened.
  3. Open the workspace from within the HEW IDE - following the instructions to connect to the target interface as the project opens.
  4. Select "Build" from the HEW "Build" menu - the demo application should build without errors.
  5. When the build completes a dialogue box will appear asking if you want the compiled binary to be downloaded to the microcontroller flash memory - select "yes" to program the flash and start a debug session.
Served web Pages
The served IO page
Configuration items specific to this demo are contained in FreeRTOS/Demo/RX600_RX62N-RSK_GNURX/RTOSDemo/FreeRTOSConfig.h or FreeRTOS/Demo/RX600_RX62N-RDK_GNURX/RTOSDemo/FreeRTOSConfig.h for the RSK and RDK hardware respectively. The constants defined in these file can be edited to suit your application. In particular -
Interrupts can be written using the standard GNURX GCC compiler syntax. For example, the demo application defines the high frequency timer using:
/* Function prototype. */
static void prvTimer2IntHandler( void ) __attribute__((interrupt));
/* Function definition. */
    the demo, so interrupts are just left disabled. */
    __asm volatile( "SETPSW	I" );
It is suggested that a compare match timer is used to generate the tick interrupt, and an example implementation of vApplicationSetupTimerInterrupt() that uses compare match timer 0 is included in both main-full.c and main-blinky.c within this demo application. Vects.c (also within the demo application) then installs vTickISR() in the CMTU0_CMT0 vector (offset 0x70). It is suggested that the provided example implementations are used in most cases.
