The RTOS download includes a lot of
example projects that are pre-configured
to work “out of the box”. This is to ensure users can get a working RTOS project running on
real hardware in a very short time. It is however impossible to support every
combination of microcontroller, compiler and development board, and we are often
asked to provide an example that does not rely on any of these variables. The
code provided on this page is provided for that purpose. The simplicity of the
code means it also serves as a good starter project for people who are not yet
familiar with FreeRTOS.
The source code does not access any hardware specific IO. For example, it just
increments variables instead of attempting to toggle an LED. However, unlike
the pre-packaged examples, it does required the user to
create their own
compiler project. That involves:
Starting with a working (non RTOS) project to ensure the correct
start up files and linker scripts are being used.
Including the correct RTOS source files. Use
existing official RTOS demo projects as a reference.
Including the correct compiler include paths, which must include the
RTOS kernel header files (FreeRTOS/Source/include in the RTOS download)
and the portable layer header file (FreeRTOS/Source/[compiler]/[architecture]/portmacro.h
in the RTOS download).
Defining a FreeRTOSConfig.h file – or at least – copying a FreeRTOSConfig.h
from an official RTOS demo that closely matches the project being created.
Here is a description of the example’s functionality:
The main() Function
main() creates the tasks and software timers described in this section, before
starting the scheduler.
The Queue Send task
The queue send task is implemented by the prvQueueSendTask() function.
The task uses the FreeRTOS vTaskDelayUntil()
and xQueueSend() API functions to
periodically send the number 100 on a queue. The period is set to 200ms. See
the comments in the function for more details.
The Queue Receive task
The queue receive task is implemented by the prvQueueReceiveTask() function.
The task uses the FreeRTOS xQueueReceive() API function
to receive values from a queue. The values received are those sent by the queue
send task. The queue receive task increments the ulCountOfItemsReceivedOnQueue
variable each time it receives the value 100. Therefore, as values are sent to
the queue every 200ms, the value of ulCountOfItemsReceivedOnQueue will increase
by 5 every second.
An example software timer
A software timer
is created with an auto reloading period of 1000ms. The
timer’s callback function increments the ulCountOfTimerCallbackExecutions
variable each time it is called. Therefore the value of
ulCountOfTimerCallbackExecutions will count seconds.
The FreeRTOS RTOS tick hook (or callback) function
The tick hook function executes in the context of the FreeRTOS tick interrupt.
The function ‘gives’ a semaphore every 500th time it executes. The semaphore
is used to synchronise with the event semaphore task, which is described next.
In this example, the tick interrupt is used in preference of an interrupt generated
by a peripheral to ensure the hardware neutrality is maintained.
The event semaphore task
The event semaphore task uses the FreeRTOS xSemaphoreTake()
API function to wait for the semaphore that is given by the RTOS tick hook function.
The task increments the ulCountOfReceivedSemaphores variable each time the semaphore is
received. As the semaphore is given every 500ms (assuming a tick frequency of
1KHz), the value of ulCountOfReceivedSemaphores will increase by 2 each second.
NOTE: A semaphore is used for example purposes. In a real application it
might be preferable to use a
direct to task notification,
which will be faster and use less RAM.
The idle hook (or callback) function
The idle hook function queries the amount of free FreeRTOS heap space available.
See vApplicationIdleHook() in the code.
The malloc failed and stack overflow hook (or callback) functions
These two hook functions are provided as examples, but do not contain any
functionality.
Source Code
Search for TODO in the source files for places where modifications might be
required.
/* Kernel includes. */
#include "FreeRTOS.h" /* Must come first. */
#include "task.h" /* RTOS task related API prototypes. */
#include "queue.h" /* RTOS queue related API prototypes. */
#include "timers.h" /* Software timer related API prototypes. */
#include "semphr.h" /* Semaphore related API prototypes. */
/* TODO Add any manufacture supplied header files can be included
here. */
#include "hardware.h"
/* Priorities at which the tasks are created. The event semaphore task is
given the maximum priority of ( configMAX_PRIORITIES - 1 ) to ensure it runs as
soon as the semaphore is given. */
#define mainQUEUE_RECEIVE_TASK_PRIORITY ( tskIDLE_PRIORITY + 2 )
#define mainQUEUE_SEND_TASK_PRIORITY ( tskIDLE_PRIORITY + 1 )
#define mainEVENT_SEMAPHORE_TASK_PRIORITY ( configMAX_PRIORITIES - 1 )
/* The rate at which data is sent to the queue, specified in milliseconds, and
converted to ticks using the pdMS_TO_TICKS() macro. */
#define mainQUEUE_SEND_PERIOD_MS pdMS_TO_TICKS( 200 )
/* The period of the example software timer, specified in milliseconds, and
#define mainSOFTWARE_TIMER_PERIOD_MS pdMS_TO_TICKS( 1000 )
/* The number of items the queue can hold. This is 1 as the receive task
has a higher priority than the send task, so will remove items as they are added,
meaning the send task should always find the queue empty. */
#define mainQUEUE_LENGTH ( 1 )
* TODO: Implement this function for any hardware specific clock configuration
* that was not already performed before main() was called.
static void prvSetupHardware( void );
* The queue send and receive tasks as described in the comments at the top of
* this file.
static void prvQueueReceiveTask( void *pvParameters );
static void prvQueueSendTask( void *pvParameters );
* The callback function assigned to the example software timer as described at
* the top of this file.
static void vExampleTimerCallback( TimerHandle_t xTimer );
* The event semaphore task as described at the top of this file.
static void prvEventSemaphoreTask( void *pvParameters );
/* The queue used by the queue send and queue receive tasks. */
static QueueHandle_t xQueue = NULL;
/* The semaphore (in this case binary) that is used by the FreeRTOS tick hook
* function and the event semaphore task.
static SemaphoreHandle_t xEventSemaphore = NULL;
/* The counters used by the various examples. The usage is described in the
* comments at the top of this file.
static volatile uint32_t ulCountOfTimerCallbackExecutions = 0;
static volatile uint32_t ulCountOfItemsReceivedOnQueue = 0;
static volatile uint32_t ulCountOfReceivedSemaphores = 0;
int main(void)
TimerHandle_t xExampleSoftwareTimer = NULL;
/* Configure the system ready to run the demo. The clock configuration
can be done here if it was not done before main() was called. */
prvSetupHardware();
/* Create the queue used by the queue send and queue receive tasks. */
xQueue = xQueueCreate( /* The number of items the queue can hold. */
mainQUEUE_LENGTH,
/* The size of each item the queue holds. */
sizeof( uint32_t ) );
/* Create the semaphore used by the FreeRTOS tick hook function and the
event semaphore task. NOTE: A semaphore is used for example purposes,
using a direct to task notification will be faster! */
xEventSemaphore = xSemaphoreCreateBinary();
/* Create the queue receive task as described in the comments at the top
of this file. */
xTaskCreate( /* The function that implements the task. */
prvQueueReceiveTask,
/* Text name for the task, just to help debugging. */
"Rx",
/* The size (in words) of the stack that should be created
for the task. */
configMINIMAL_STACK_SIZE,
/* A parameter that can be passed into the task. Not used
in this simple demo. */
NULL,
/* The priority to assign to the task. tskIDLE_PRIORITY
(which is 0) is the lowest priority. configMAX_PRIORITIES - 1
is the highest priority. */
mainQUEUE_RECEIVE_TASK_PRIORITY,
/* Used to obtain a handle to the created task. Not used in
this simple demo, so set to NULL. */
NULL );
/* Create the queue send task in exactly the same way. Again, this is
described in the comments at the top of the file. */
xTaskCreate( prvQueueSendTask,
"TX",
NULL,
mainQUEUE_SEND_TASK_PRIORITY,
NULL );
/* Create the task that is synchronised with an interrupt using the
xEventSemaphore semaphore. */
xTaskCreate( prvEventSemaphoreTask,
"Sem",
NULL,
mainEVENT_SEMAPHORE_TASK_PRIORITY,
NULL );
/* Create the software timer as described in the comments at the top of
this file. */
xExampleSoftwareTimer = xTimerCreate( /* A text name, purely to help
debugging. */
( const char * ) "LEDTimer",
/* The timer period, in this case
1000ms (1s). */
mainSOFTWARE_TIMER_PERIOD_MS,
/* This is a periodic timer, so
xAutoReload is set to pdTRUE. */
pdTRUE,
/* The ID is not used, so can be set
to anything. */
( void * ) 0,
/* The callback function that switches
the LED off. */
/* Start the created timer. A block time of zero is used as the timer
command queue cannot possibly be full here (this is the first timer to
be created, and it is not yet running). */
xTimerStart( xExampleSoftwareTimer, 0 );
/* Start the tasks and timer running. */
vTaskStartScheduler();
/* If all is well, the scheduler will now be running, and the following line
will never be reached. If the following line does execute, then there was
insufficient FreeRTOS heap memory available for the idle and/or timer tasks
to be created. See the memory management section on the FreeRTOS web site
for more details. */
for( ;; );
/* The timer has expired. Count the number of times this happens. The
timer that calls this function is an auto re-load timer, so it will
execute periodically. */
ulCountOfTimerCallbackExecutions++;
TickType_t xNextWakeTime;
const uint32_t ulValueToSend = 100UL;
/* Initialise xNextWakeTime - this only needs to be done once. */
xNextWakeTime = xTaskGetTickCount();
for( ;; )
/* Place this task in the blocked state until it is time to run again.
The block time is specified in ticks, the constant used converts ticks
to ms. The task will not consume any CPU time while it is in the
Blocked state. */
vTaskDelayUntil( &xNextWakeTime, mainQUEUE_SEND_PERIOD_MS );
/* Send to the queue - causing the queue receive task to unblock and
increment its counter. 0 is used as the block time so the sending
operation will not block - it shouldn't need to block as the queue
should always be empty at this point in the code. */
xQueueSend( xQueue, &ulValueToSend, 0 );
uint32_t ulReceivedValue;
for( ;; )
/* Wait until something arrives in the queue - this task will block
indefinitely provided INCLUDE_vTaskSuspend is set to 1 in
FreeRTOSConfig.h. */
xQueueReceive( xQueue, &ulReceivedValue, portMAX_DELAY );
/* To get here something must have been received from the queue, but
is it the expected value? If it is, increment the counter. */
if( ulReceivedValue == 100UL )
/* Count the number of items that have been received correctly. */
ulCountOfItemsReceivedOnQueue++;
for( ;; )
/* Block until the semaphore is 'given'. NOTE:
A semaphore is used for example purposes. In a real application it might
be preferable to use a direct to task notification, which will be faster
and use less RAM. */
xSemaphoreTake( xEventSemaphore, portMAX_DELAY );
/* Count the number of times the semaphore is received. */
ulCountOfReceivedSemaphores++;
void vApplicationTickHook( void )
static uint32_t ulCount = 0;
/* The RTOS tick hook function is enabled by setting configUSE_TICK_HOOK to
1 in FreeRTOSConfig.h.
"Give" the semaphore on every 500th tick interrupt. */
ulCount++;
if( ulCount >= 500UL )
/* This function is called from an interrupt context (the RTOS tick
interrupt), so only ISR safe API functions can be used (those that end
in "FromISR()".
xHigherPriorityTaskWoken was initialised to pdFALSE, and will be set to
pdTRUE by xSemaphoreGiveFromISR() if giving the semaphore unblocked a
task that has equal or higher priority than the interrupted task.
might be preferable to use a direct to task notification,
which will be faster and use less RAM. */
xSemaphoreGiveFromISR( xEventSemaphore, &xHigherPriorityTaskWoken );
ulCount = 0UL;
/* If xHigherPriorityTaskWoken is pdTRUE then a context switch should
normally be performed before leaving the interrupt (because during the
execution of the interrupt a task of equal or higher priority than the
running task was unblocked). The syntax required to context switch from
an interrupt is port dependent, so check the documentation of the port you
are using.
In this case, the function is running in the context of the tick interrupt,
which will automatically check for the higher priority task to run anyway,
so no further action is required. */
void vApplicationMallocFailedHook( void )
/* The malloc failed hook is enabled by setting
configUSE_MALLOC_FAILED_HOOK to 1 in FreeRTOSConfig.h.
Called if a call to pvPortMalloc() fails because there is insufficient
free memory available in the FreeRTOS heap. pvPortMalloc() is called
internally by FreeRTOS API functions that create tasks, queues, software
timers, and semaphores. The size of the FreeRTOS heap is set by the
configTOTAL_HEAP_SIZE configuration constant in FreeRTOSConfig.h. */
for( ;; );
void vApplicationStackOverflowHook( TaskHandle_t xTask, char *pcTaskName )
( void ) pcTaskName;
( void ) xTask;
/* Run time stack overflow checking is performed if
configconfigCHECK_FOR_STACK_OVERFLOW is defined to 1 or 2. This hook
function is called if a stack overflow is detected. pxCurrentTCB can be
inspected in the debugger if the task name passed into this function is
corrupt. */
for( ;; );
volatile size_t xFreeStackSpace;
/* The idle task hook is enabled by setting configUSE_IDLE_HOOK to 1 in
FreeRTOSConfig.h.
This function is called on each cycle of the idle task. In this case it
does nothing useful, other than report the amount of FreeRTOS heap that
remains unallocated. */
xFreeStackSpace = xPortGetFreeHeapSize();
if( xFreeStackSpace > 100 )
/* By now, the kernel has allocated everything it is going to, so
if there is a lot of heap remaining unallocated then
the value of configTOTAL_HEAP_SIZE in FreeRTOSConfig.h can be
reduced accordingly. */
/* Ensure all priority bits are assigned as preemption priority bits
if using a ARM Cortex-M microcontroller. */
NVIC_SetPriorityGrouping( 0 );
/* TODO: Setup the clocks, etc. here, if they were not configured before
