ARM Cortex-M33 (ARMv8-M) Demo for NXP LPCXpresso55S69 Development Board
Using MCUXpresso IDE
This page documents a pre-configured FreeRTOS project that targets the ARM Cortex-M33 core on the NXP LPCXpresso55S69 Development Board. The project uses the MCUXpresso IDE and GCC compiler to build the FreeRTOS ARMv8-M GCC port. The project demonstrates using the ARM Cortex-M33 TrustZone and the ARM Cortex-M33 Memory Protection Unit (MPU).
  1. Source Code Organization
The project files for this demo are located in the FreeRTOS/Demo/CORTEX_MPU_M33F_NXP_LPC55S69_MCUXpresso/Projects/MCUXpresso directory. The project file for the secure side of the ARM Cortex-M33 core has the usual Eclipse project name .project and is located in the FreeRTOS/Demo/CORTEX_MPU_M33F_NXP_LPC55S69_MCUXpresso/Projects/MCUXpresso/Secure directory. The project file for the non-secure side of the ARM Cortex-M33 core has the usual Eclipse project name .project and is located in the FreeRTOS/Demo/CORTEX_MPU_M33F_NXP_LPC55S69_MCUXpresso/Projects/MCUXpresso/NonSecure directory.The FreeRTOS ARMv8-M Cortex-M33 port files compiled in these two projects are organized as follows:
  1. TrustZone Demo
TrustZone Demo
  • NonSecure Callback:
    void prvCallback( void )
  • Secure Calling Task:
TrustZone Demo Call Sequence
  • RW Task:
  • RO Task:
  1. Launch the MCUXpresso IDE. Note that you need the MCUXpresso IDE version 10.3.1 or higher to be able to build and run this demo.
  2. Choose the workspace directory and click "Launch".
    MCUXpresso IDE - Launcher
    MCUXpresso IDE - Launcher. Click to enlarge.
  3. Open the Import Project dialog by clicking "File --> Import...".
    MCUXpresso IDE - Import
    MCUXpresso IDE - Import. Click to enlarge.
  4. Select "General --> Existing Projects into Workspace" and click "Next".
  5. Click "Browse..." next to "Select root directory" and select FreeRTOS/Demo/CORTEX_MPU_M33F_NXP_LPC55S69_MCUXpresso/Projects/MCUXpresso directory. Two projects, namely FreeRTOSDemo_s and FreeRTOSDemo_ns, should be visible in the Projects pane as shown below. Click "Finish".
  6. Build the secure project by right clicking on FreeRTOSDemo_s and selecting "Build Project".
    MCUXpresso IDE - Build Secure Project
    MCUXpresso IDE - Build Secure Project. Click to enlarge.
  7. Build the non-secure project by right clicking on FreeRTOSDemo_ns and selecting "Build Project".
    MCUXpresso IDE - Build Non-Secure Project
    MCUXpresso IDE - Build Non-Secure Project. Click to enlarge.
  8. Power up the board using "Debug Link (P6)" micro USB port.
  9. Select the non-secure project by clicking FreeRTOSDemo_ns. Go to "Debug your project" in the Quickstart Panel and click on "Program flash action using LinkServer" in the dropdown as shown below.
    MCUXpresso IDE - Flash the Non-Secure Binary
    MCUXpresso IDE - Flash the Non-Secure Binary. Click to enlarge.
  10. LPC-LINK2 probe should be shown in the "Probes Discovered" window. Click "OK".
  11. SWD Device 0 should be selected in the "SWD Configuration" window. Click "OK".
  12. You should see "Finished writing Flash successfully" in the logs. Click "OK".
  13. Power cycle the board by disconnecting and reconnecting the micro USB cable.
  14. Select the secure project by clicking FreeRTOSDemo_s. Go to "Debug your project" in the Quickstart Panel and click on "Program flash action using LinkServer" in the dropdown as shown below.
    MCUXpresso IDE - Flash the Secure Binary
    MCUXpresso IDE - Flash the Secure Binary. Click to enlarge.
  15. LPC-LINK2 probe should be shown in the "Probes Discovered" window. Click "OK".
  16. SWD Device 0 should be selected in the "SWD Configuration" window. Click "OK".
  17. You should see "Finished writing Flash successfully" in the logs. Click "OK".
  18. Power cycle the board by disconnecting and reconnecting the micro USB cable.
  19. Go to "Debug your project" in the Quickstart Panel and click "Debug using LinkServer probes" in the dropdown as shown below to start the debug session.
    MCUXpresso IDE - Start the Debug Session
    MCUXpresso IDE - Start the Debug Session. Click to enlarge.
  • Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_MPU_M33F_NXP_LPC55S69_MCUXpresso/Projects/MCUXpresso/Config/FreeRTOSConfig.h. The constants defined in that file can be edited to suit your application. The following configuration options are specific to the ARM Cortex-M33 port:
