The FreeRTOS tutorial book
FreeRTOS Recursive Mutexes
A mutex used recursively can be ‘taken’ repeatedly by the owner. The mutex doesn’t become available again until the owner has called
xSemaphoreGiveRecursive() for each successful xSemaphoreTakeRecursive() request. For example, if a task successfully ‘takes’ the same
mutex 5 times then the mutex will not be available to any other task until it has also ‘given’ the mutex back exactly five times.
This type of semaphore uses a priority inheritance mechanism so a task ‘taking’ a semaphore MUST ALWAYS ‘give’ the semaphore back once
the semaphore it is no longer required.
Mutex type semaphores cannot be used from within interrupt service routines.
They include a priority inheritance mechanism which only makes sense if
the mutex is given and taken from a task, not an interrupt.
An interrupt cannot block to wait for a resource that is guarded by a
mutex to become available.
