RTOS Task Notifications
Used As Light Weight Binary Semaphores
Unblocking an RTOS task with a direct notification is 45% faster and uses less RAM than unblocking a task with a binary semaphore. This page demonstrates how this is done.
A binary semaphore is a semaphore that has a maximum count of 1, hence the 'binary' name. A task can only 'take' the semaphore if it is available, and the semaphore is only available if its count is 1.
When a task notification is used in place of a binary semaphore the receiving task's notification value is used in place of the binary semaphore's count value, and the ulTaskNotifyTake() (or ulTaskNotifyTakeIndexed()) API function is used in place of the semaphore's xSemaphoreTake() API function. The ulTaskNotifyTake() function's xClearOnExit parameter is set to pdTRUE so the count value is returned to zero each time the notification is taken - emulating a binary semaphore.
See the example below.
1/* This is an example of a transmit function in a generic2 peripheral driver. An RTOS task calls the transmit function,3 then waits in the Blocked state (so not using an CPU time)4 until it is notified that the transmission is complete. The5 transmission is performed by a DMA, and the DMA end interrupt6 is used to notify the task. */78/* Stores the handle of the task that will be notified when the9 transmission is complete. */10static TaskHandle_t xTaskToNotify = NULL;1112/* The index within the target task's array of task notifications13 to use. */14const UBaseType_t xArrayIndex = 1;1516/* The peripheral driver's transmit function. */17void StartTransmission( uint8_t *pcData, size_t xDataLength )18{19 /* At this point xTaskToNotify should be NULL as no transmission20 is in progress. A mutex can be used to guard access to the21 peripheral if necessary. */22 configASSERT( xTaskToNotify == NULL );2324 /* Store the handle of the calling task. */25 xTaskToNotify = xTaskGetCurrentTaskHandle();2627 /* Start the transmission - an interrupt is generated when the28 transmission is complete. */29 vStartTransmit( pcData, xDatalength );30}31/*-----------------------------------------------------------*/3233/* The transmit end interrupt. */34void vTransmitEndISR( void )35{36BaseType_t xHigherPriorityTaskWoken = pdFALSE;3738 /* At this point xTaskToNotify should not be NULL as39 a transmission was in progress. */40 configASSERT( xTaskToNotify != NULL );4142 /* Notify the task that the transmission is complete. */43 vTaskNotifyGiveIndexedFromISR( xTaskToNotify,44 xArrayIndex,45 &xHigherPriorityTaskWoken );4647 /* There are no transmissions in progress, so no tasks48 to notify. */49 xTaskToNotify = NULL;5051 /* If xHigherPriorityTaskWoken is now set to pdTRUE then a52 context switch should be performed to ensure the interrupt53 returns directly to the highest priority task. The macro used54 for this purpose is dependent on the port in use and may be55 called portEND_SWITCHING_ISR(). */56 portYIELD_FROM_ISR( xHigherPriorityTaskWoken );57}58/*-----------------------------------------------------------*/5960/* The task that initiates the transmission, then enters the61 Blocked state (so not consuming any CPU time) to wait for it62 to complete. */63void vAFunctionCalledFromATask( uint8_t ucDataToTransmit,64 size_t xDataLength )65{66uint32_t ulNotificationValue;67const TickType_t xMaxBlockTime = pdMS_TO_TICKS( 200 );6869 /* Start the transmission by calling the function shown above. */70 StartTransmission( ucDataToTransmit, xDataLength );7172 /* Wait to be notified that the transmission is complete. Note73 the first parameter is pdTRUE, which has the effect of clearing74 the task's notification value back to 0, making the notification75 value act like a binary (rather than a counting) semaphore. */76 ulNotificationValue = ulTaskNotifyTakeIndexed( xArrayIndex,77 pdTRUE,78 xMaxBlockTime );7980 if( ulNotificationValue == 1 )81 {82 /* The transmission ended as expected. */83 }84 else85 {86 /* The call to ulTaskNotifyTake() timed out. */87 }88}
