RTOS Task Notifications
Used As Light Weight Event Group
Related pages:
An event group is a set of binary flags (or bits),
to each of which the application writer can assign a meaning. An RTOS task can
enter the Blocked state to wait for one or more flags within the group to become active. The RTOS
task does not consume any CPU time while it is in the Blocked state.
When a task notification is used in place of an event group the receiving task’s
notification value is used in place
of the event group, bits within the receiving task’s notification value are used
as event flags, and the xTaskNotifyWait()
API function is used in place of the event group’s xEventGroupWaitBits() API function.
Likewise, bits are set using the xTaskNotify() and
xTaskNotifyFromISR() API functions (with their eAction
parameter set to eSetBits) in place
of the xEventGroupSetBits() and xEventGroupSetBitsFromISR() functions respectively.
xTaskNotifyFromISR() has significant performance benefits when compared
to xEventGroupSetBitsFromISR() because xTaskNotifyFromISR() executes entirely in
the ISR, whereas xEventGroupSetBitsFromISR() must defer some processing to the
RTOS daemon task.
Unlike when using an event group the receiving task cannot specify that it
only wants to leave the Blocked state when a combination of bits are active at the
same time. Instead the task is unblocked when any bit becomes active, and must
test for bit combinations itself.
See the example below:
/* This example demonstrates a single RTOS task being used to process
events that originate from two separate interrupt service routines -
a transmit interrupt and a receive interrupt. Many peripherals will
use the same handler for both, in which case the peripheral's
interrupt status register can simply be bitwise ORed with the
receiving task's notification value.
First bits are defined to represent each interrupt source. */
#define TX_BIT 0x01
#define RX_BIT 0x02
/* The handle of the task that will receive notifications from the
interrupts. The handle was obtained when the task
was created. */
static TaskHandle_t xHandlingTask;
/* The implementation of the transmit interrupt service routine. */
void vTxISR( void )
prvClearInterrupt();
/* Notify the task that the transmission is complete by setting the TX_BIT
in the task's notification value. */
xTaskNotifyFromISR( xHandlingTask,
TX_BIT,
eSetBits,
&xHigherPriorityTaskWoken );
/* If xHigherPriorityTaskWoken is now set to pdTRUE then a context switch
should be performed to ensure the interrupt returns directly to the highest
priority task. The macro used for this purpose is dependent on the port in
use and may be called portEND_SWITCHING_ISR(). */
/* The implementation of the receive interrupt service routine is identical
except for the bit that gets set in the receiving task's notification value. */
void vRxISR( void )
/* Notify the task that the reception is complete by setting the RX_BIT
RX_BIT,
eSetBits,
/* The implementation of the task that is notified by the interrupt service
routines. */
static void prvHandlingTask( void *pvParameter )
const TickType_t xMaxBlockTime = pdMS_TO_TICKS( 500 );
BaseType_t xResult;
for( ;; )
/* Wait to be notified of an interrupt. */
xResult = xTaskNotifyWait( pdFALSE, /* Don't clear bits on entry. */
ULONG_MAX, /* Clear all bits on exit. */
&ulNotifiedValue, /* Stores the notified value. */
xMaxBlockTime );
if( xResult == pdPASS )
/* A notification was received. See which bits were set. */
if( ( ulNotifiedValue & TX_BIT ) != 0 )
/* The TX ISR has set a bit. */
prvProcessTx();
if( ( ulNotifiedValue & RX_BIT ) != 0 )
/* The RX ISR has set a bit. */
prvProcessRx();
/* Did not receive a notification within the expected time. */
prvCheckForErrors();
