TI SimpleLink CC3220 RTOS Demo
Using the FreeRTOS Cortex-M port for Code Composer (CCS)
Texas Instruments CC3220 SimpleLink WiFi Launchpad Development Kit
The SimpleLink CC3220 LaunchPad Development Kit
This page documents the Code Composer Studio (CCS) demo application that targets the Texas Instruments SimpleLink CC3220 WiFi MCU. The CC3220SF part has an ARM Cortex-M4 core, 1MB Flash, 256KB of RAM and enhanced security features.
Note: Even though the CC3220 has an ARM Cortex-M4 core, it does not have a floating point unit (FPU), and therefore uses the FreeRTOS Cortex-M3 port.
The demo project is pre-configured to run on the SimpleLink Wi-Fi CC3220SF Wireless Microcontroller LaunchPad Development Kit, and can be configured to create either a simple blinky demo, or a comprehensive test and demo application. The blinky demo uses FreeRTOS’s tickless idle mode to reduce power consumption.
“Tickless” Low Power Operation
Stopping the RTOS tick interrupt allows the microcontroller to remain in a power saving state until either an interrupt occurs, or it is time for the RTOS kernel to transition a task into the Ready state. Note that only the generic ARM Cortex-M tickless implementation is demonstrated. Tailoring the tickless implementation so it uses CC3220 specific clocks and low power modes will greatly increase the power saving that can be achieved.
See the Low Power Support and the Low Power RTOS For ARM Cortex-M MCUs pages for further information.
IMPORTANT! Notes on using the TI CC3220 SimpleLink ARM Cortex-M4F Demo
The FreeRTOS download contains the source code for every FreeRTOS port and all the demo applications, so contains a lot more files than are required by the CC3220 SimpleLink demo. See the Source Code Organization section of this website for a description of the downloaded files.
CCS uses the Ecliplse IDE, so the CCS project has the normal Eclipse name .project. The project is located in the /FreeRTOS/Demo/CORTEX_M4_SimpleLink_CC3220SF_CCS directory.
Building and Running the CCS3220 SimpleLink RTOS Application
The RTOS demo projects can be configured to build either a simple blinky project that also demonstrates FreeRTOS’s generic ARM Cortex-M tickless low power mode, or a comprehensive test and demo application. The constant configCREATE_SIMPLE_TICKLESS_DEMO, which is located at the top of the project’s FreeRTOSConfig.h file, is used to switch between the two.
  • The simple tickless demo is created if configCREATE_SIMPLE_TICKLESS_DEMO is set to 1.
  • The comprehensive demo is created if configCREATE_SIMPLE_TICKLESS_DEMO is set to 0.
Note the comments at the top of this page about the difference in power saving that can be achieved by the demonstrated generic tickless implementation when compared to what could be achieved using a CC3220 specific tickless implementation.
The demo uses an LED built onto the Launchpad development kit, so no hardware setup is required.
Note: The CCS project references files using relative paths. The project may fail to build if a directory path is changed or if a file is moved. Eclipse’s ‘export’ features can be used to convert the project into a stand-alone project that only uses directories under the directory in which the .project file is located.
  1. Connect the Launchpad development kit directly to the host computer (the computer running CCS) using the hardware’s USB connector – no other debug interface is required.
  2. Start the CCS Eclipse IDE, and either create a new or select an existing workspace when prompted.
  3. Select “Import” from the IDE’s “File” menu. The dialogue box shown below will appear. Select “Code Composer Studio->CCS Projects”, as shown below.
    Importing the ARM Cortex-M4 RTOS demo project into the CCS Eclipse IDE
  4. In the next dialogue box, select /FreeRTOS/Demo/CORTEX_M4_SimpleLink_CC3220SF_CCS as the root directory. Make sure the RTOSDemo project is checked in the “Projects” area, and that the Copy Projects Into Workspace box is not checked, before clicking the Finish button (see the image below for the correct check box states).
    Make sure RTOSDemo is checked, and “Copy projects into workspace” is not checked
  5. Select “Build All” from the CCS Eclipse “Project” menu to build the demo project.
  6. Select “Debug” from the Eclipse “Run” menu to program the microcontroller’s flash memory and start a debug session.
The simply blinky example, using tick-less operation
The simple tickless example is created when configCREATE_SIMPLE_TICKLESS_DEMO is set to 1. configCREATE_SIMPLE_TICKLESS_DEMO is defined at the top of FreeRTOSConfig.h.
The FreeRTOS tickless idle mode stops the periodic RTOS tick interrupt during idle periods (periods when there are no application tasks that are able to execute). The blinky example creates two tasks that only unblock once every second, so the tick interrupt is stopped for the majority of the execution time.
Note the comments at the top of this page about the difference in power saving that can be achieved by the demonstrated generic tickless implementation when compared to what could be achieved using an CC3220 specific tickless implementation. The generic tickless idle mode uses the SysTick clock, which is fast and only 24-bits, and therefore overflows many times between the demo task entering and then subsequently exiting the Blocked state – and each overflow generates an interrupt.
Setting configCREATE_SIMPLE_TICKLESS_DEMO to 1 results in main() calling main_blinky():
    prvQueueSendTask() sends the value 100 to the queue every second.
    prvQueueReceiveTask() blocks to wait for data to arrive on the queue. Each time the value 100 is received from the queue it flashes the LED. As data is sent to the queue every second, the LED will flash every second.
The comprehensive example is created when configCREATE_SIMPLE_TICKLESS_DEMO is set to 0. configCREATE_SIMPLE_TICKLESS_DEMO is defined in FreeRTOSConfig.h.
Setting configCREATE_SIMPLE_TICKLESS_DEMO to 0 results in main() calling main_full():
  • The main_full() Function:
    main_full() creates a set of standard demo tasks, the Register Test tasks, and starts the scheduler.
  • The “Reg Test” Tasks:
    The reg test tasks test the context switching mechanism by filling each general purpose microcontroller register with a known value, then continuously checking that each register maintains its expected value for the lifetime of the task.
  • The “Check” Task:
    The “Check” task monitors the status of all the other tasks in the system, looking for a task either stalling or reporting an error. It toggles an LED each time it is called.
    If the LED is toggling every three seconds then the check task has determined the demo is running as expected. If the LED is toggling every 200ms then at least one error has been found.
Priority assignment
The lowest priority on a ARM Cortex-M core is in fact 255 – however different ARM Cortex-M microcontroller manufacturers implement a different number of priority bits and supply library functions that expect priorities to be specified in different ways. For example, the TI CC3220 ARM Cortex-M4 SimpleLink MCU implements 3 priority bits, which allows for a maximum of 8 different priority levels (0 to 7 inclusive). The lowest priority being the highest number. Some library functions will use the numeric value 7 as the lowest priority, while others will use the numeric value 224 as the lowest (which is 7 << 5, and how the ARM Cortex-M sees the value internally in the interrupt controller). These two numbers are defined by configLIBRARY_LOWEST_INTERRUPT_PRIORITY and configKERNEL_INTERRUPT_PRIORITY respectively in FreeRTOSConfig.h. The highest priority that can be assigned is always zero.
Implementing interrupt service routines
Interrupt service routines that cause a context switch have no special requirements. An example is provided below:
Configuration items specific to these demos are contained in the FreeRTOSConfig.h file located in the same directory as the project file. The constants defined in FreeRTOSConfig.h can be edited to meet the needs of your application. In particular –
    This sets the frequency of the RTOS tick interrupt. The supplied value of 1KHz is useful for testing the RTOS kernel functionality, but is faster than most applications require. Lowering this value will improve efficiency.
Each port #defines ‘BaseType_t’ to equal the most efficient data type for that processor. All ARM Cortex-M4F ports define BaseType_t to be of type long.
