The benefit of a co-routines lower RAM usage when compared to an equivalent task comes at the cost of some restrictions on how a co-routine can be used. Co-routines
are more restrictive and complex to use than tasks.
Sharing a stack
The stack of a co-routine is not maintained when a co-routine blocks. This means variables allocated on the stack will most
probably lose their values. To overcome this a variable that must maintain its value across a blocking call must be declared
as static. For example:
void vACoRoutineFunction( CoRoutineHandle_t xHandle,
UBaseType_t uxIndex )
static char c = 'a';
crSTART( xHandle );
for( ;; )
// If we set c to equal 'b' here ...
c = 'b';
// ... then make a blocking call ...
crDELAY( xHandle, 10 );
// ... c will only be guaranteed to still
// equal 'b' here if it is declared static
// (as it is here).
crEND();
Another consequence of sharing a stack is that calls to API functions that could cause the co-routine to block can only be made from the
co-routine function itself – not from within a function called by the co-routine. For example:
void vACoRoutineFunction( CoRoutineHandle_t xHandle, UBaseType_t uxIndex )
crSTART( xHandle );
for( ;; )
// It is fine to make a blocking call here,
// but a blocking call cannot be made from within
// vACalledFunction().
vACalledFunction();
crEND();
void vACalledFunction( void )
// Cannot make a blocking call here!
Use of switch statements
The default co-routine implementation included in the FreeRTOS download does not permit a blocking call to be made from
within a switch statement. For example:
crSTART( xHandle );
for( ;; )
switch( aVariable )
case 1 : // Cannot make a blocking call here!
break;
default: // Or here!
crEND();
