vTaskSetTimeOutState()
[Task Utilities]
task.h
void vTaskSetTimeOutState( TimeOut_t * const pxTimeOut );
vTaskSetTimeOutState() is used with xTaskCheckForTimeOut(). vTaskSetTimeOutState() is called to set the initial condition, after which xTaskCheckForTimeOut() can be called to check for a timeout condition, and adjust the remaining block time if a timeout has not occurred.
pxTimeOut   A pointer to a structure that will be initialized to hold information necessary to determine if a timeout has occurred.
An example is provided on the xTaskCheckForTimeOut() documentation page.
Latest News
FreeRTOS v10.2.1 is available for immediate download. MIT licensed, includes 64-bit RISC-V, NXP Cortex-M33 demo, Nuvoton Cortex-M23 demo & STM32H745 dual core (AMP) demo.
Careers
FreeRTOS Partners
Cadence Tensilica Cortes
Espressif ESP32
IAR Partner
Mediatek
Renesas
RISC-V
SiFIve RISC-V
OpenRTOS and SafeRTOS
