xSemaphoreCreateMutexStatic
[Semaphores]
semphr. h
SemaphoreHandle_t xSemaphoreCreateMutexStatic(
StaticSemaphore_t *pxMutexBuffer );
Creates a mutex, and returns
a handle by which the created mutex can be referenced. Mutexes cannot be used
in interrupt service routines.
configSUPPORT_STATIC_ALLOCATION and
configUSE_MUTEXES must both be set to 1 in FreeRTOSConfig.h for
xSemaphoreCreateMutexStatic() to be available.
Each mutex require a small amount of RAM that is used to hold the
mutex's state. If a mutex is created using xSemaphoreCreateMutex()
If a mutex is created using xSemaphoreCreateMutexStatic()
time. See the Static Vs
Mutexes are taken using xSemaphoreTake(), and given
using xSemaphoreGive().
xSemaphoreTakeRecursive() and xSemaphoreGiveRecursive() can only be used on
mutexes created using xSemaphoreCreateResursiveMutex().
Mutexes and binary semaphores are very similar but
have some subtle differences: Mutexes include a priority inheritance mechanism,
binary semaphores do not. This makes binary semaphores the better choice for
implementing synchronisation (between tasks or between tasks and an interrupt),
and mutexes the better choice for implementing simple mutual exclusion.
The priority of a task that 'takes' a mutex will be temporarily raised if another
task of higher priority attempts to obtain the same mutex. The task that owns
the mutex 'inherits' the priority of the task attempting to 'take' the same
mutex. This means the mutex must always be 'given' back - otherwise the higher
priority task will never be able to obtain the mutex, and the lower priority
task will never 'disinherit' the priority.
An example of a mutex being used to implement mutual
exclusion is provided on the xSemaphoreTake() documentation page.
A binary semaphore need not be given back once obtained, so task synchronisation
can be implemented by one task/interrupt continuously 'giving' the semaphore
while another continuously 'takes' the semaphore. This is demonstrated by
the sample code on the xSemaphoreGiveFromISR() documentation page.
Note that the same functionality can be achieved in a more efficient way using
a direct to task notification.
Handles to both mutexes and binary semaphores are assigned to variables of type
SemaphoreHandle_t, and can be used in any task level (as opposed to interrupt
safe) API function that takes a parameter of that type.
pxMutexBuffer
Must point to a variable of type StaticSemaphore_t, which
will be used to hold the mutex type semaphore's state.
Return:
If the mutex type semaphore was created successfully then a handle to
the created mutex is returned. If the mutex was not
created because pxMutexBuffer was NULL then NULL is returned.
/* Create a mutex semaphore without using any dynamic memory
allocation. The mutex's data structures will be saved into
the xMutexBuffer variable. */
xSemaphore = xSemaphoreCreateMutexStatic( &xMutexBuffer );
handle will not be NULL. */
configASSERT( xSemaphore );
