Macro to recursively release, or ‘give’, a mutex type semaphore.
The mutex must have previously been created using a call to
xSemaphoreCreateRecursiveMutex();
configUSE_RECURSIVE_MUTEXES must be set to 1 in FreeRTOSConfig.h for this
macro to be available.
A mutex used recursively can be ‘taken’ repeatedly by the owner. The mutex
doesn’t become available again until the owner has called
xSemaphoreGiveRecursive() for each successful ‘take’ request. For example,
if a task successfully ‘takes’ the same mutex 5 times then the mutex will
not be available to any other task until it has also ‘given’ the mutex back
exactly five times.
xMutex
A handle to the mutex being released, or ‘given’. This is the handle returned by xSemaphoreCreateRecursiveMutex().
pdTRUE if the semaphore was successfully given.
// ... Do other things.
if( xMutex != NULL )
// See if we can obtain the mutex. If the mutex is not available
// shared resource.
// xSemaphoreTakeRecursive() are made on the same mutex. In real
// no sense. Instead the calls are likely to be buried inside
// three times. Again it is unlikely that real code would have
// these calls sequentially, it would be more likely that the calls
// to xSemaphoreGiveRecursive() would be called as a call stack
// unwound. This is just for demonstrative purposes.
