xStreamBufferBytesAvailable()
[RTOS Stream Buffer API]
stream_buffer.h
size_t xStreamBufferBytesAvailable( StreamBufferHandle_t xStreamBuffer );
Queries a stream buffer to see how much data it contains, which is equal to the number of bytes that can be read from the stream buffer before the stream buffer would be empty.
The number of bytes that can be read from the stream buffer before the stream buffer would be empty.
