xStreamBufferIsEmpty()
[RTOS Stream Buffer API]
stream_buffer.h
BaseType_t xStreamBufferIsEmpty( StreamBufferHandle_t xStreamBuffer );
Queries a stream buffer to see if it is empty. A stream buffer is empty if it does not contain any data.
If the stream buffer is empty then pdTRUE is returned. Otherwise pdFALSE is returned.
