xSemaphoreTakeRecursive
[Semaphores]
semphr. h
xSemaphoreTakeRecursive( SemaphoreHandle_t xMutex,
TickType_t xTicksToWait );
Macro to recursively obtain, or 'take', a mutex type semaphore.
The mutex must have previously been created using a call to
xSemaphoreCreateRecursiveMutex();
configUSE_RECURSIVE_MUTEXES must be set to 1 in FreeRTOSConfig.h for this
macro to be available.
A mutex used recursively can be 'taken' repeatedly by the owner. The mutex
doesn't become available again until the owner has called
xSemaphoreGiveRecursive() for each successful 'take' request. For example,
if a task successfully 'takes' the same mutex 5 times then the mutex will
not be available to any other task until it has also 'given' the mutex back
exactly five times.
- Parameters:
xMutex | A handle to the mutex being obtained. This is the handle returned by xSemaphoreCreateRecursiveMutex(). |
xTicksToWait | The time in ticks to wait for the semaphore to become available. The macro portTICK_PERIOD_MS can be used to convert this to a real time. A block time of zero can be used to poll the semaphore. If the task already owns the semaphore then xSemaphoreTakeRecursive() will return immediately no matter what the value of xTicksToWait. |
- Returns:
- pdTRUE if the semaphore was obtained. pdFALSE if xTicksToWait expired without the semaphore becoming available.
// ... Do other things.
if( xMutex != NULL )
// See if we can obtain the mutex. If the mutex is not available
// shared resource.
// xSemaphoreTakeRecursive() are made on the same mutex. In real
// no sense. Instead the calls are likely to be buried inside
// three times. Again it is unlikely that real code would have
// these calls sequentially, but instead buried in a more complex
// call structure. This is just for illustrative purposes.
