Transport Interface
Custom Implementations
Applications can provide their own implementation of the Transport Interface if the example implementations don't match the underlying network or TLS stack. An implementation has two parts. The first is the definition of a network context data structure that wraps an underlying data stream, such as a socket handle or a TLS context. The second is a pair of functions that can send and receive data on that network context - these two functions just wrap whichever network send and receive functions you are already using within functions that have the prototype expected by the transport interface structure. There is a worked example below.
The Transport Interface structure is defined as follows:
struct NetworkContext;
void * pBuffer,
size_t bytesToRecv );
const void * pBuffer,
size_t bytesToSend );
typedef struct TransportOutVector
const void * iov_base;
size_t iov_len;
} TransportOutVector_t;
typedef int32_t ( * TransportWritev_t )( NetworkContext_t * pNetworkContext,
TransportOutVector_t * pIoVec,
size_t ioVecCount );
TransportRecv_t recv; /* Receive function (see above) */
TransportSend_t send; /* Send function (see above) */
TransportWritev_t writev; /* Writev function (see above) */
NetworkContext_t * pNetworkContext; /* Network context (see above) */
} TransportInterface_t;
Transport Interface Structure
Worked Example
This example describes how to create a transport interface for the FreeRTOS-Plus-TCP stack
(this is for demonstration purposes only as the FreeRTOS source code download already contains a transport interface for FreeRTOS-Plus-TCP). For simplicity the example is using TCP without TLS or
other form of encryption. Production IoT devices should always use encrypted
connections and the FreeRTOS download includes transport interfaces that use
FreeRTOS-Plus-TCP with TLS stacks.
Starting point
It is recommended to ensure your application is able to successfully send and
receive from the network before creating a network transport interface - that
way the transport interface is just wrapping send and receive functions that are
already working.
FreeRTOS-Plus-TCP sockets
are stored in variables of type Socket_t. So the NetworkContext structure
can be defined as:
Socket_t tcpSocket;
Defining a NetworkContext structure that just contains a FreeRTOS-Plus-TCP socket.
Next, the FreeRTOS-Plus-TCP
send and
receive functions need to
be wrapped by functions that have the prototype expected by the transport interface's
send and receive functions. The example below also demonstrates how to obtain the socket used
by the send and receive functions from the NetworkContext parameter:
void * pBuffer,
int32_t socketStatus = 1;
if( bytesToRecv == 1 )
if( socketStatus > 0 )
return socketStatus;
int32_t socketStatus;
socketStatus = 0;
Implementing the transport send and receive functions for FreeRTOS-Plus-TCP
Finally, the code below shows how to populate the transport interface structure
with the
NetworkContext structure, and
transport_send() and
transport_recv() functions defined above:
pTransport->writev = NULL;
Example Implementations
The transport interface implementations included in the FreeRTOS download are split into two files - a wrapper C file specific to the TCP stack, and a supplemental C file specific to using a TLS stack with the selected TCP stack. For example, to use FreeRTOS-Plus-TCP with mbedTLS, build sockets_wrapper.c from the network_transport/freertos_plus_tcp directory in the source code distribution, then build using_mbedtls.c from the using_mbedtls subdirectory.
