Using AWS IoT ExpressLink
Other featured FreeRTOS reference integrations demonstrate the
long-term support (LTS) versions of the FreeRTOS libraries, along with hardware backed
security, and are used to help create secure and authenticated cloud connections. This page shows how to use AWS IoT ExpressLink
modules (from here on "ExpressLink") to more easily achieve the same goal.
ExpressLink modules are hardware Wi-Fi and cellular
modules with built-in cloud connectivity, over-the-air (OTA) updates, and hardware backed secure storage for encryption
and authentication keys. Host processors that execute IoT applications communicate with ExpressLink through a serial port
using a simple AT command set. All ExpressLink modules use the same command set, irrespective of the underlying radio types
(e.g. Wi-Fi, cellular). By using ExpressLink modules, IoT application writers no longer have to handle the complexity of
radio, security, and IoT libraries. Instead, these developers can focus on their differentiating functionality.
ExpressLink modules can be used from any device with a serial port, from tiny 8-bit microcontrollers (MCUs) to rack
mounted servers. This page highlights ExpressLink demos created by
ST's I-Cube-ExpressLink
that target a range of STM32 MCUs.
Figure 1: Design of connected applications with AWS IoT ExpressLink
(Click to Enlarge)
Demonstrated security features and functions
All AWS IoT ExpressLink modules implement the security best practices described in the following subsections.
ExpressLink modules establish a secure and encrypted connection with AWS IoT Core using
Transport Layer Security (TLS). This connection is mutually authenticated, ensuring the identity of both the device
and the cloud. Each module is pre-configured with a unique identifier, private key, and certificate necessary to establish
this secure connection. The certificate is signed by a Certificate Authority (CA) that is already registered with AWS by
the module vendor. This solves the scalability, potential for error, and security problems associated with IoT device
provisioning, while reducing complexity and costs.
ExpressLink modules use hardware backed secure storage to keep device identity and private keys safe.
No disclosure of confidential information within the supply chain
Onboarding is the process of binding the module's credentials to a "thing" inside the
AWS IoT registry of the OEM's account. ExpressLink uses a novel
onboarding-by-claim mechanism to do this automatically the first time the device powers
up. This late binding removes the need to provide any secret information, such as private keys, to suppliers with the
IoT device's supply chain.
ExpressLink modules include a hardware root of trust backed secure bootloader that cryptographically verifies its
firmware integrity at each boot stage, helping to prevent unauthorized ExpressLink firmware modification.
The STM32 examples also use Tiny Secure Boot, ensuring ECDSA signature verification of the host (the MCU that
communicates with ExpressLink) software. Tiny SecureBoot has a compact footprint of less than 15K of Flash. They also
leverage the ExpressLink module’s capability to verify the integrity (hash) and authenticity (signature) of the new
host images received over the air – offloading these cryptography tasks from the host application.
Secure over the air (OTA) updates
OTA updates enhance security by patching security vulnerabilities and bugs in already deployed devices. ExpressLink's
OTA feature enables secure firmware updates for both the ExpressLink module and host MCU.
Module updates occur without disrupting the host MCU. Each module comes pre-provisioned with an OTA "birth certificate"
used to verify its firmware updates were authorized by the module manufacturer. The module signals the host MCU to accept or
reject the update after successful verification, ensuring the compatibility.
Host MCU updates can receive any file type, not just new firmware versions. They use the same mechanism as module updates,
except that host MCU OTA certificates can't be pre-provisioned. Instead, the certificate must first be generated, uploaded,
and securely stored within the ExpressLink module. The ST examples provide a script for this purpose.
Authenticating firmware updates in the ExpressLink module offloads this heavy cryptographic task from the host application.
Getting started with I-CUBE-ExpressLink
I-Cube-ExpressLink
is a CMSIS pack containing an extensive collection of FreeRTOS projects that use ExpressLink and target
STM32 Arm Cortex MCUs.
It includes an ExpressLink driver which is a single wrapper that manages ExpressLink commands and responses over a serial interface. These commands and responses are
common to, and used extensively in application examples that run on, >10 STM32 development boards. The pack also includes a rich set of tools that simplify the Host
OTA process and help you to deploy at scale, reducing the number of steps and eliminating the need for familiarity with the AWS console.
The FreeRTOS projects demonstrate typical IoT scenarios:
- Transmitting sensor data to the cloud.
- Sending and receiving messages to and from cloud.
- Using AWS IoT Shadows to control LEDs and other actuators from the cloud. (ExpressLink
includes Shadow functionality.)
- Updating host firmware over-the-air.
- Managing ExpressLink module events.
These examples function seamlessly with both ExpressLink cellular and Wi-Fi modules, and don't require any
code modification.
To get started, watch the STM32 ExpressLink tutorial videos:
then visit the
I-Cube-ExpressLink github repository to begin development. The repository provides a comprehensive list of
features, including the ExpressLink driver, example source code, as well as instructions for installing the packs,
generating, building, and running the FreeRTOS ExpressLink demos.
