The FreeRTOS download contains the source code for all the FreeRTOS ports, so
contains many more files than are needed by the RX64M e2studio projects.
new project.
The e2studio projects have the usual Eclipse project name .project.
The project that uses the Renesas compiler is located in the
FreeRTOS/Demo/RX600_RX64M_RSK_Renesas_e2studio directory. The project
that uses the GCC compiler is located in the FreeRTOS/Demo/RX600_RX64M_RSK_GCC_e2studio
directory. These are the directories that must be selected when importing the
projects into the Eclipse workspace.
Building and Running the Renesas RX64M Demo Application
The RTOS demo projects can be configured to build either
a simple blinky project, or a comprehensive test and demo application. The constant
mainCREATE_SIMPLE_BLINKY_DEMO_ONLY, which is defined at the top of main.c, is used
to switch between the two. The comprehensive demo is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set
to 0.
The simple demo is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1.
The demos use the LEDs built onto the RSK development board, so no hardware
set up is required.
Note: Some of the source files built by the e2studio projects are included
in the project using a project relative path, so the project will fail to build
if the FreeRTOS directory structure has been altered from that found in the .zip file.
Start the e2studio Eclipse IDE and either create a new or select an existing
workspace when prompted.
Select "Import" from the IDE's "File" menu. The dialogue box shown below
will appear. Select "General->Existing Project into Workspace", as shown below.
In the next dialogue box, select FreeRTOS/Demo/RX600_RX64M_RSK_Renesas_e2studio
as the root directory if you are using the Renesas compiler, or
FreeRTOS/Demo/RX600_RX64M_RSK_GCC_e2studio if you are using
the GCC compiler.
Make sure the RTOSDemo project is checked in the "Projects" area,
Open main.c and locate the mainCREATE_SIMPLE_BLINKY_DEMO_ONLY definition,
which is near the top of the file. Set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to 1 to
build the simply blinky style (starter) project. Set
mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to 0 to build the comprehensive test
Select "Build All" from the e2studio Eclipse "Project" menu to build
the demo project, and wait for the build to complete.
Ensure the E1 debug adapter (which comes with the RSK starter kit) is
connected between the RX64M RSK hardware and the host computer. If you
configure the launch configurations as per the images below then there is
no need to supply any external power.
Select "Debug Configurations" from the Eclipse "Run"
menu to configure a launch configuration that can be used to program the
microcontroller flash memory and start a debug session. Configure
the debug launch configuration as shown in the images below.
Click images to enlarge
The simply blinky example
The simple blinky example is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set
to 1. mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is defined in main.c
main() calls main_blinky():
The main_blinky() Function:
main_blinky() creates an RTOS queue, a queue send task, and a queue receive
task, before starting the scheduler.
The Queue Send Task:
The Queue Receive Task:
in main_blinky.c.
prvQueueReceiveTask() blocks to wait for data to arrive on the RTOS queue.
Each time the value 100 is received from the queue it toggles LED 0.
As data is sent to the queue every 200ms, the LED will toggle every
200ms.
The comprehensive example is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set
to 0. mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is defined in main.c.
main() calls main_full():
The main_full() Function:
main_full() creates a set of standard demo tasks, some application specific
test tasks, and a pseudo randomiser task, before starting the scheduler.
The pseudo randomiser task is just used to ensure some variation is
added to the sequence in which the test tasks execute, and in so doing,
improve the test coverage.
The "Reg Test" Tasks:
The reg test tasks test the context switching mechanism by filling each
MCU register with a known value, then continuously checking that each
register maintains its expected value for the lifetime of the task.
The "Check" Task:
The "Check" task monitors the status of all the other tasks in
the system, looking for a task either stalling or reporting an error.
It toggles LED 3 each time it is called.
If the LED is toggling every three seconds then the check task has not
detected any stalled tasks or received any error reports. If the LED
is toggling every 200ms then at least one error has been found.
The Standard Flash Tasks:
LED 0, LED 1, and LED 2 are controlled by the standard demo flash tasks. Each
LED will toggle with a fixed but unique frequency.
Configuration items specific to this demo are contained in FreeRTOS/Demo/RX600_RX64M_RSK_Renesas_e2studio/Source/FreeRTOSConfig.h or
FreeRTOS/Demo/RX600_RX64M_RSK_GCC_e2studio/src/FreeRTOSConfig.h for the Renesas compiler
and GCC compiler projects respectively. The
constants defined in these files can be edited to suit your application. In particular -
configTICK_RATE_HZ
This sets the frequency of the RTOS tick. The supplied value of 1KHz is useful for
testing the RTOS kernel functionality but is faster than most applications need. Lowering this frequency will improve efficiency.
This defines the interrupt priority used by the RTOS kernel for the timer and software interrupts.
This should always be set to
the lowest interrupt priority, which is 1 for the RX64M. See
This defines the maximum interrupt priority from which RTOS API functions
can be called. Interrupts at or below this priority can call FreeRTOS API
functions provided that the API function ends in 'FromISR'.
Interrupts above this priority cannot call any FreeRTOS API functions but
will not be effected by anything the RTOS kernel is doing. This makes them
suitable for functionality that requires very high temporal accuracy (motor
control for example).
The RX64M port layer #defines 'BaseType_t' to 'long'.
Interrupts can be written using the standard compiler syntax. Examples for both
the Renesas and GCC compilers are provided below.
Often an ISR wants to cause a context switch so the task that is returned to when
the ISR completes is different to the task that the ISR originally interrupted. This would
be the case if the ISR caused a task to unblock, and the unblocked task had a
priority above that of the task that was already in the Running state. This
can be achieved by calling portYIELD_FROM_ISR(), which takes a single parameter.
The parameter must be 0 if a context switch is not required, or non-zero if
a context switch is required. portYIELD_FROM_ISR() is used in the examples
below.
/* Pragma used to install the interrupt. The 'enable' used in the pragma
/* Function definition. */
/* Interrupts are already enabled here. See comment above. */
/* xSemaphoreGiveFromISR() is an interrupt safe FreeRTOS function. It is
assumed the semaphore has already been created. If giving the semaphore
unblocks a task, and the task that is unblocked has a priority above the
parameter will get set to pdTRUE inside the xSemaphoreGiveFromISR()
function. */
xSemaphoreGiveFromISR( xSemaphore, &lHigherPriorityTaskWoken );
/* The function prototype uses the interrupt attribute. */
__asm volatile( "SETPSW I" );
function. */
FreeRTOS also requires exclusive use of a timer that is capable of generating the tick interrupt - but
it is up to the application writer to define which timer is used. To do this
the application must define a function called vApplicationSetupTimerInterrupt() to
configure the tick interrupt using the chosen peripheral, then install vTickISR() in the corresponding
location within the interrupt vector table.
It is suggested that a compare match timer is used to generate the tick interrupt, and an example
implementation of vApplicationSetupTimerInterrupt() that uses compare match timer 0 is
included in main.c within this demo application.
Source/Portable/MemMang/heap_4.c is included in the RX64M demo application project to provide the memory
full information.
