task.h
BaseType_t xTaskGetStaticBuffers( TaskHandle_t xTask,
StackType_t ** ppuxStackBuffer,
StaticTask_t ** ppxTaskBuffer );
must be defined as 1 for this function to be available. See the RTOS Configuration documentation for more information.
Retrieve pointers to a statically created task's data structure buffer and stack buffer. These are the same buffers that are supplied at the time of creation.
xTask
The task whose buffers will be retrieved.
ppuxStackBuffer
Used to return a pointer to the task's stack buffer.
ppxTaskBuffer
Used to return a pointer to the task's data structure buffer.
