vTaskDelayUntil()
[Task Control]
task. h
1void vTaskDelayUntil( TickType_t *pxPreviousWakeTime,
2 const TickType_t xTimeIncrement );
INCLUDE_vTaskDelayUntil
must be defined as 1 for this function to be available. See the RTOS Configuration documentation for more information.
Delay a task until a specified time. This function can be used by periodic tasks to ensure a constant execution frequency.
This function differs from
vTaskDelay()
in one important aspect:
vTaskDelay()
specifies a time at which the task wishes to unblock relative to the time at which
vTaskDelay()
is called, whereas
vTaskDelayUntil()
specifies an absolute time at which the task wishes to unblock.
vTaskDelay()
will cause a task to block for the specified number of ticks from the time
vTaskDelay()
is called. It is therefore difficult to use
vTaskDelay()
by itself to generate a fixed execution frequency as the time between a task unblocking following a call to
vTaskDelay()
and that task next calling
vTaskDelay()
may not be fixed (the task may take a different path through the code between calls, or may get interrupted or preempted a different number of times each time it executes).
Whereas
vTaskDelay()
specifies a wake time relative to the time at which the function is called,
vTaskDelayUntil()
specifies the absolute (exact) time at which it wishes to unblock.
It should be noted that
vTaskDelayUntil()
will return immediately (without blocking) if it is used to specify a wake time that is already in the past. Therefore a task using
vTaskDelayUntil()
to execute periodically will have to re-calculate its required wake time if the periodic execution is halted for any reason (for example, the task is temporarily placed into the Suspended state) causing the task to miss one or more periodic executions. This can be detected by checking the variable passed by reference as the
pxPreviousWakeTime
parameter against the current tick count. This is however not necessary under most usage scenarios.
The constant
portTICK_PERIOD_MS
can be used to calculate real time from the tick rate - with the resolution of one tick period.
This function must not be called while the RTOS scheduler has been suspended by a call to
vTaskSuspendAll()
  • pxPreviousWakeTime
    Pointer to a variable that holds the time at which the task was last unblocked. The variable must be initialised with the current time prior to its first use (see the example below). Following this the variable is automatically updated within
    vTaskDelayUntil()
  • xTimeIncrement
    The cycle time period. The task will be unblocked at time
    (*pxPreviousWakeTime + xTimeIncrement)
    . Calling
    vTaskDelayUntil
    with the same
    xTimeIncrement
    parameter value will cause the task to execute with a fixed interval period.
1// Perform an action every 10 ticks.
2void vTaskFunction( void * pvParameters )
3{
4 TickType_t xLastWakeTime;
5 const TickType_t xFrequency = 10;
6
7 // Initialise the xLastWakeTime variable with the current time.
8 xLastWakeTime = xTaskGetTickCount();
9
10 for( ;; )
11 {
12 // Wait for the next cycle.
13 vTaskDelayUntil( &xLastWakeTime, xFrequency );
14
15 // Perform action here.
16 }
17}
