Key points of interest within the FreeRTOS source code contain empty macros that an application can re-define
for the purpose of providing application specific trace facilities. The application need only implement those macros
of particular interest – with unused macros remaining empty and therefore not impacting the application timing.
Macro definitions must occur before the inclusion of FreeRTOS.h. The easiest place to define trace macros is at the bottom of FreeRTOSConfig.h, or in a separate
header file that is included from the bottom of FreeRTOSConfig.h.
The table below describes the available macros. The macro parameters are used to indicate which task, queue, semaphore or mutex was
associated with the event being recorded.
Macro definition | Description |
traceTASK_INCREMENT_TICK(xTickCount) | Called during the tick interrupt. |
traceTASK_SWITCHED_OUT() | Called before a new task is selected to run. At this point pxCurrentTCB contains the handle of the task about to leave the Running state. |
traceTASK_SWITCHED_IN() | Called after a task has been selected to run. At this point pxCurrentTCB contains the handle of the task about to enter the Running state. |
traceMOVED_TASK_TO_READY_STATE(xTask) | Called when a task is transitioned into the Ready state. |
traceBLOCKING_ON_QUEUE_RECEIVE(xQueue) | Indicates that the currently executing task is about to block following an attempt to read from an empty queue, or an attempt to ‘take’ an empty semaphore or mutex. |
traceBLOCKING_ON_QUEUE_SEND(xQueue) | Indicates that the currently executing task is about to block following an attempt to write to a full queue. |
traceGIVE_MUTEX_RECURSIVE(xMutex) | Called from within xSemaphoreGiveRecursive(). |
traceGIVE_MUTEX_RECURSIVE_FAILED(xMutex) | Called from within xSemaphoreGiveRecursive(). |
traceQUEUE_CREATE(pxNewQueue) | Called from within xQueueCreate() or xQueueCreateStatic() if the queue was successfully created. |
traceQUEUE_CREATE_FAILED() | Called from within xQueueCreate() or xQueueCreateStatic() if the queue was not successfully created due to there being insufficient heap memory available. |
traceCREATE_MUTEX(pxNewMutex) | Called from within xSemaphoreCreateMutex() if the mutex was successfully created. |
traceCREATE_MUTEX_FAILED() | Called from within xSemaphoreCreateMutex() if the mutex was not successfully created due to there being insufficient heap memory available. |
traceGIVE_MUTEX_RECURSIVE(xMutex) | Called from within xSemaphoreGiveRecursive() if the mutex was successfully ‘given’. |
traceGIVE_MUTEX_RECURSIVE_FAILED(xMutex) | Called from within xSemaphoreGiveRecursive() if the mutex was not successfully given as the calling task was not the mutex owner. |
traceTAKE_MUTEX_RECURSIVE(xMutex) | Called from within xQueueTakeMutexRecursive(). |
traceCREATE_COUNTING_SEMAPHORE() | Called from within xSemaphoreCreateCounting() if the semaphore was successfully created. |
traceCREATE_COUNTING_SEMAPHORE_FAILED() | Called from within xSemaphoreCreateCounting() if the semaphore was not successfully created due to insufficient heap memory being available. |
traceQUEUE_SEND(xQueue) | Called from within xQueueSend(), xQueueSendToFront(), xQueueSendToBack(), or any of the semaphore ‘give’ functions, when the queue send was successful. |
traceQUEUE_SEND_FAILED(xQueue) | Called from within xQueueSend(), xQueueSendToFront(), xQueueSendToBack(), or any of the semaphore ‘give’ functions when the queue send operation failed due to the queue being full (after any block time that was specified). |
traceQUEUE_RECEIVE(xQueue) | Called from within xQueueReceive() or any of the semaphore ‘take’ functions when the queue receive was successful. |
traceQUEUE_RECEIVE_FAILED(xQueue) | Called from within xQueueReceive() or any of the semaphore ‘take’ functions when the queue receive operation failed because the queue was empty (after any block time that was specified). |
traceQUEUE_PEEK(xQueue) | Called from within xQueuePeek() |
traceQUEUE_SEND_FROM_ISR(xQueue) | Called from within xQueueSendFromISR() when the send operation was successful. |
traceQUEUE_SEND_FROM_ISR_FAILED(xQueue) | Called from within xQueueSendFromISR() when the send operation failed due to the queue already being full. |
traceQUEUE_RECEIVE_FROM_ISR(xQueue) | Called from within xQueueReceiveFromISR() when the receive operation was successful. |
traceQUEUE_RECEIVE_FROM_ISR_FAILED(xQueue) | Called from within xQueueReceiveFromISR() when the receive operation failed due to the queue already being empty. |
traceQUEUE_DELETE(xQueue) | Called from within vQueueDelete(). |
traceTASK_CREATE(xTask) | Called from within xTaskCreate() (or xTaskCreateStatic()) when the task is successfully created. |
traceTASK_CREATE_FAILED(pxNewTCB) | Called from within xTaskCreate() (or xTaskCreateStatic()) when the task was not successfully created due to there being insufficient heap space available. |
traceTASK_DELETE(xTask) | Called from within vTaskDelete(). |
traceTASK_DELAY_UNTIL() | Called from within vTaskDelayUntil(). |
traceTASK_DELAY() | Called from within vTaskDelay(). |
traceTASK_PRIORITY_SET(xTask,uxNewPriority) | Called from within vTaskPrioritySet(). |
traceTASK_SUSPEND(xTask) | Called from within vTaskSuspend(). |
traceTASK_RESUME(xTask) | Called from within vTaskResume(). |
traceTASK_RESUME_FROM_ISR(xTask) | Called from within xTaskResumeFromISR(). |
traceTIMER_COMMAND_RECEIVED(pxTimer, xCommandID, xCommandValue) | Called within the timer service task each time it receives a command, before the command is actually processed. |
traceTIMER_COMMAND_SEND(pxTimer, xCommandID, xOptionalValue, xStatus) | Called from within any API function that sends a command to the timer service task, for example, xTimerReset(), xTimerStop(), etc. xStatus will be pdFAIL if the command was not successfully sent to the timer command queue. |
traceTIMER_CREATE(pxNewTimer) | Called from within xTimerCreate() if the timer was successfully created. |
traceTIMER_CREATE_FAILED() | Called from within xTimerCreate() if the timer was not successfully created due to there being insufficient heap memory available. |
traceTIMER_EXPIRED(pxTimer) | Called when a software timer expires, before the timer callback is executed. |
