xStreamBufferGetStaticBuffers()
[RTOS Stream Buffer API]
stream_buffer.h
 BaseType_t xStreamBufferGetStaticBuffers( StreamBufferHandle_t xStreamBuffer,
                                           uint8_t ** ppucStreamBufferStorageArea,
                                           StaticStreamBuffer_t ** ppxStaticStreamBuffer );
Retrieve pointers to a statically created stream buffer's data structure buffer and storage area buffer. These are the same buffers that are supplied at the time of creation.
xStreamBuffer   The stream buffer whose data structure buffer and storage area buffer will be retrieved.
ppucStreamBufferStorageArea   Used to return a pointer to the stream buffer's storage area buffer.
ppxStaticStreamBuffer   Used to return a pointer to the stream buffer's data structure buffer.
