vStreamBufferSetStreamBufferNotificationIndex
[RTOS Stream Buffer API]
stream_buffer.h
void vStreamBufferSetStreamBufferNotificationIndex( StreamBufferHandle_t xStreamBuffer,
                                                    UBaseType_t uxNotificationIndex );
Sets the task notification index used for the supplied stream buffer. Successive calls to stream buffer APIs (like xStreamBufferSend or xStreamBufferReceive) for this stream buffer will use this new index for their task notifications.
Enable stream buffer functionality by including the FreeRTOS/source/stream_buffer.c source file in the build and by setting the configUSE_STREAM_BUFFERS configuration constant to 1 in FreeRTOSConfig.h.
xStreamBuffer
The handle of the stream buffer for which the task notification index is set.
uxNotificationIndex
The task notification index to set.
