message_buffer.h
BaseType_t xMessageBufferResetFromISR( MessageBufferHandle_t xMessageBuffer );
An interrupt safe version of the xMessageBufferReset()
API function.
Resets a message buffer to its initial, empty state. Any data that was in the message buffer is discarded. A message buffer can only be
reset if there are no tasks blocked waiting to either send to or receive from the message buffer.
Use xMessageBufferReset()
to reset a message buffer from a task. Use xMessageBufferResetFromISR()
to reset a
message buffer from an interrupt service routine (ISR).
source file in the build (as message
buffers use stream buffers).
- xMessageBuffer
- The handle of the message buffer to reset.
If the message buffer is reset then pdPASS is returned. If there was a task blocked waiting to send to or read from the message buffer then
the message buffer will not be reset and pdFAIL is returned.
