stream_buffer.h
BaseType_t xStreamBufferResetFromISR( StreamBufferHandle_t xStreamBuffer );
An interrupt safe version of the xStreamBufferReset()
API function.
Resets a stream buffer to its initial, empty, state. Any data that was in the stream buffer is discarded.
A stream buffer can only be reset if there are no tasks blocked waiting to either send to or receive from the stream buffer.
Use xStreamBufferReset()
to reset a stream buffer from a task. Use xStreamBufferResetFromISR()
from an interrupt service routine (ISR).
xStreamBuffer
- The handle of the stream buffer to reset.
If the stream buffer is reset then pdPASS is returned. If there was a task blocked waiting to send to or read from the stream buffer
then the stream buffer will not be reset and pdFAIL is returned.
