xStreamBatchingBufferCreateStatic / xStreamBatchingBufferCreateStaticWithCallback
[RTOS Stream Buffer API]
stream_buffer.h
StreamBufferHandle_t xStreamBatchingBufferCreateStatic( size_t xBufferSizeBytes,
size_t xTriggerLevelBytes,
uint8_t *pucStreamBufferStorageArea,
StaticStreamBuffer_t *pxStaticStreamBuffer );
StreamBufferHandle_t xStreamBatchingBufferCreateStaticWithCallback(
StaticStreamBuffer_t *pxStaticStreamBuffer,
Creates a new stream batching buffer using statically allocated memory. See
xStreamBatchingBufferCreate() for a version that uses dynamically allocated memory.
configSUPPORT_STATIC_ALLOCATION must be set to 1 in
FreeRTOSConfig.h for xStreamBatchingBufferCreateStatic()
to be available.
configUSE_STREAM_BUFFERS must be set to 1 in FreeRTOSConfig.h for xStreamBatchingBufferCreateStatic()
to be available.
Additionally, configUSE_SB_COMPLETED_CALLBACK must be set to 1 in FreeRTOSConfig.h
for xStreamBatchingBufferCreateStaticWithCallback()
to be available.
Enable stream buffer functionality by including the FreeRTOS/source/stream_buffer.c
source file in the build.
The difference between a stream buffer and a stream batching buffer is when a task performs a read on a non-empty buffer:
- A task that reads from a non-empty stream buffer returns immediately regardless of the amount of data in the buffer.
- A task that reads from a non-empty stream batching buffer blocks until the amount of data in the buffer exceeds the trigger
level or the block time expires.
xBufferSizeBytes
The size, in bytes, of the buffer pointed to by the pucStreamBufferStorageArea
parameter.
xTriggerLevelBytes
The number of bytes that must be in the stream batching buffer to unblock a task calling xStreamBufferReceive
before
Must point to a uint8_t
array that is at least xBufferSizeBytes
big. This is the array to which streams
are copied when they are written to the stream batching buffer.
Must point to a variable of type StaticStreamBuffer_t
, which will be used to hold the stream batching buffer's
data structure.
The callback invoked when a number of bytes at least equal to the trigger level are sent to the stream batching buffer. If the
parameter is NULL, it will use the default implementation provided by the sbSEND_COMPLETED
macro. To enable the
callback, configUSE_SB_COMPLETED_CALLBACK
must be set to 1 in FreeRTOSConfig.h. The send completed callback function
must have the prototype defined by StreamBufferCallbackFunction_t
, which is:
void vSendCallbackFunction( StreamBufferHandle_t xStreamBuffer,
BaseType_t xIsInsideISR,
The callback invoked when more than zero bytes are read from a stream batching buffer. If the parameter is NULL, it will use the
default implementation provided by the sbRECEIVE_COMPLETED
macro. To enable the callback, configUSE_SB_COMPLETED_CALLBACK
must be set to 1 in FreeRTOSConfig.h. The receive completed callback function must have the prototype defined by
, which is:
void vReceiveCallbackFunction( StreamBufferHandle_t xStreamBuffer,
If the stream batching buffer is created successfully, then a handle to the created stream batching buffer is returned. If either
ppucStreamBufferStorageArea
or ppxStaticStreamBuffer
are NULL, then NULL is returned.
Example use:
static uint8_t ucStorageBuffer[ STORAGE_SIZE_BYTES ];
StaticStreamBuffer_t xStreamBufferStruct;
void MyFunction( void )
StreamBufferHandle_t xStreamBatchingBuffer;
const size_t xTriggerLevel = 1;
xStreamBatchingBuffer = xStreamBatchingBufferCreateStatic( sizeof( ucStorageBuffer ),
xTriggerLevel,
ucStorageBuffer,
&xStreamBufferStruct );
